Now in 993 land ...
aigel's Avatar
G-tech fun. What's a 0-60 on 81 SC?
I just got an early x-mas present to myself today. A G-tech pro. The older model that is.
I went out and had some fun on a dead end road in my stock US spec 81SC. The best I could get without raping the clutch and transmission was 6.6 seconds for 0-60. That is wiith a rather slow upshift on the 915. What do you think? What's the factory number and what is a contemporary test number for an 81 SC? I sure feel that I could get down to 6s if I was able to power shift and did a clutch drop at 4krpm. The LSD helps already not to spin tires much when getting on it from the dead stop.
I also did HP numbers. Got anything from 155-171 at the rear wheels assuming 3k pounds total weight with me in there and quite a few interior pieces and one seat missing ... The distribution seemed to have it's maximum around 160-165. That actually makes pretty good sense, coming from what? 185 at the crank?
The road was too short for 1/4 mile times, I'll do those another time.
Now the next present to myself should be SSI and a nice sport muffler. Then I could see if I can see a mighty 10-15% increase in umph and start trying to G-tech race my american muscle car!
Cheers, George
81 SC (sold)
Old 12-17-2003, 07:26 PM
Doug E's Avatar
Interesting - I always wondered what my '81 Coupe was capable of as well. Unfortunately I've never done any kind of testing like that but at least now I've got some kind of benchmark.
Thanks.
Doug
'81 SC Coupe
Old 12-17-2003, 07:32 PM
Somewhere in the Midwest
MotoSook's Avatar
Ha! I got a G-tech Pro as an early gift to myself too!
6.6 Seconds is pretty good for an 81SC. I'll have to wait until spring for my runs, or I could go for it sans the front end
HP numbers are no good until you really know the weight and the loss. But it'll be good for relative changes in HP.
Old 12-17-2003, 07:35 PM
Now in 993 land ...
aigel's Avatar
The G-tech is a great toy. It won't tell you a whole lot, I agree. But it is great to measure before and after modifications or if you are fine tuning a car. Absolute numbers need to be taken with a grain of salt, which is true for most chassis dynos too, BTW.
George
81 SC (sold)
Old 12-17-2003, 07:45 PM
drag racing the short bus
dd74's Avatar
0-60 = 6 seconds for an '83.
0-60 = 5.5 for a '78.
Both are Road and Track as I recall.
The Terror of Tiny Town
Old 12-17-2003, 10:48 PM
Now in 993 land ...
aigel's Avatar
Darn, they must have had some test cars that they didn't own! Of course, my valve adjustment and a tuneup are way due, but I can't see breaking below 6s without major abuse of the driveline. I will have to test again after fine tuning the mill ...
George
81 SC (sold)
Old 12-17-2003, 10:51 PM
Original Owner
tsuter's Avatar
Turbo it and you'll get 5.0 with that 3.0 SC. The "driveline" will, be fine but you might want the Sachs Power clutch but not until the stock one fails. My stock clutch lasted 20 years. 18 years WITH the turbo.
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 12-18-2003, 05:34 AM
Eric Mckenna's Avatar
5.5 for a stock 78 SC huh... wow! thats quick.. I would say mine is faster than that then.. as I have SSI's and Sport Exhaust and Nothing inside thecar and or onthe outside really for that matter, i'll have to borrow on of these G-techs and post my munbers..
great to hear..
5.5 out of a 78SC.
Famous last words..
"Hold my beer and watch this...'
" The reason the Irish are always fightin one another is that there are no other worthy opponents ".
Old 12-18-2003, 05:52 AM
Glasgow 911SC's Avatar
How much Hp did a U.S spec SC have to get 5.5 seconds? Euro (204Hp) models are quoted as 5.7 by most road test articles.
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 12-18-2003, 05:59 AM
Senior Member
Superman's Avatar
I've been meaning to get a stopwatch and see what happens. Most of you know that we dyno'd some SCs recently here and most of us made about 174 lb/ft of torque at the wheels, which is about 205 at the flywheel. And with the 20/21 cams, my torque curve is deliciously flat. So, I think the factory-specified 7.0 seconds is a joke. Like others have said, balky shifting is probably the thing that holds us back the most. If our clutches and trannies were up to the task, I think six seconds flat is very very achievable. First gear is over in a flash, ending at 40 mph. Second gear gets that last 20 mph pretty quickly too.
And with a Cool Collar, perhaps we could get close to the 917 numbers. I think they got to 100 mph in something like 3.4 seconds.
Mocha 1978 911SC. "Coco"
Old 12-18-2003, 06:55 AM
brawlins's Avatar
I did some Net research and came up with 6.7 second 0-60 timing.
If you did 6.6, that sounds pretty good.
I can't believe a 78SC can do 0-60 in 5.5 seconds without a bit of help.
By the way, the "official" Porsche stats of 7.0 seconds was for 0-62 mph (100 kph), which is probably about 6.8 seconds 0-60, buth they seem to notoriously underestimate anyway.
- Bill
1982 Porsche 911SC Coupe
1999 Porsche 911/996 Coupe
Old 12-18-2003, 09:57 AM
dd74's Avatar
Well, of course, 0-60 times involve a tremendous amount of variables. I had a G-tech, and received so many different readings, that I gave it up for a good old fashioned St. Moritz chronograph. That said, I timed my car very, very conservatively from 0 to 60, and received 6.1. What I mean by "conservative" is I started out at 1,500 RPM in second gear, and accelerated to 60.
I just don't think the 0-60 time is all that important - though it is a fun stat. And SUPERMAN is correct about the transmission et al playing a major factor in how fast the car accelerates.
Everyone at TRE estimates my car should accelerate to 60 in the low 5s, but I'm not willing to blow my clutch or break my transmission in the process.
Old 12-18-2003, 10:09 AM
brawlins's Avatar
dd74 -
What kind of car do you have? I enjoy 0-60 stats.
Side question: My speedometer is a bit fast - I think I'm probably closer to 50 than 60 when the speedometer says 60. Would the G-Tech (or similar device) also reflect an inaccurate reading in this case?
I also wonder if this is a common thing to have a fast speedometer on a 911?
Old 12-18-2003, 05:00 PM
Send a message via ICQ to old_skul
Eric, I think Carston has one, and so do I. You can borry it any time. As long as I can get a ride in your 959 someday.
Mark Szabo
1986 911 Targa 3.2 (I will miss you)
1985 Scirocco 8V (I will not miss you)
1986 Dodge B150 Ram Van (I can't believe I got $200 for you)
1987 Escort 5-speed 1.9 RIP
Old 12-18-2003, 05:11 PM
I used to read (and practically memorize) all the car mags from the late 70s and early 80s.
As I recall, most mags here in the US got 60 in 6.2 to 6.7 for the SC.
Old 12-18-2003, 05:15 PM
Go Speedracer, go!
SpeedracerIndy's Avatar
Here's the post for the article of the 1978 Road & Track test where they got 0-60 in 5.5.
1978 911 SC C&D Road Test Scan
I've seen a few statistics for the 204hp RoW SCs that said 0-100kph (62mph) in 5.7 sec.
1981 SC ROW Coupe
Old 12-18-2003, 05:37 PM
dd74's Avatar
Originally posted by brawlins
dd74 -
'74 911 with an '83 engine. 7.31 r/p. 2,340 pounds w/ 1/4 tank of fuel.
Old 12-18-2003, 05:51 PM
coolbreeze's Avatar
I really like the way the SC feels in the turns.
Old 12-18-2003, 07:23 PM
Mikkel
Guest
Posts: n/a
As far as I can remember a Euro 180HP SC will do 0-62 mph in 6,8 secs. The 204HP 81-83 Euro SC should be 6,5 secs. Still according to road tests of the time the 204 cars have been measured to 6,2 & 5,9. Probably depends....if the driver has to pay for clutch etc. then the times will be slower
Old 12-18-2003, 11:49 PM
I know the 77 Carrera 3.0 suppose to do 0 - 62 at 6.1 according to all my books. I would be surprised if the 3.0 SC's did it faster Weight difference and less hp for SC (US). I read the 3.2 (U.S.) was down around 5.5. I doubt that too. Anyways, who cares. They are all beautiful cars.
Old 12-19-2003, 07:17 AM
