Mookster's Avatar
A/C Expansion Valve
Over the summer I attempted to have my A/C recharged because it wasn't as "cool" as it should be. (In FL, marginal A/C is still better than no A/C at all). My local wrench advised that my A/C expansion valve was not working properly. The part required replacement. I passed on the replacement of the vlave due to my amp system had to be R&I. (I hate to pay a shop 3 hours what I can do in 1 hour).
I have all ready converted the the cooling system from the R12 coolant to the R134a. I have successfully replaced the expansion valve.
The part was covered with a black tar-like substance. Sticky, but easily removed. Is this normal? If this is normal, what is the stuff? Do I have to recoat the part once I recharge the A/C system?
Happy Holidays. Thanks in advance for your help.
If it has a skirt or tires, it WILL cost you money!
Old 12-21-2003, 05:06 AM
Mookster's Avatar
Anyone?
Old 12-22-2003, 02:40 AM
Not Quite Banned
Thomas Owen's Avatar
Mook, my guess would be the 'tar' prevents condensation from forming and dripping into the enclosure. I would try and replace it with something, even if some similar 'tar' from a caulking tube (Home Depot). I was able to salvage most of mine and simply recoated the valve area.
Good luck,
Thomas Owen
1972 911T
1972 911S
Old 12-22-2003, 03:36 AM
rfuerst911sc's Avatar
I could be wrong but I think the tar like substance is the sealing compound for the hole that the expansion valve mounts to/thru?
Old 12-22-2003, 05:34 AM
Irrationally exuberant
ChrisBennet's Avatar
My Dad call that stuff "Monkey Dung".
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 12-22-2003, 05:41 AM
