-   -   Bench-testing alternator (http://forums.pelicanparts.com/porsche-911-technical-forum/140515-bench-testing-alternator.html)
ohecht 12-20-2003 05:31 PM
My alternator is out of the car and has suffered a small fall onto the back of the unit.
I would like to test it, or at least verify the integrity of the connections, before reinstalling it.
Is there a way to do this? What tests and values should I look for among the connections if it is possible?
Thanks,
Olivier
nostatic 12-20-2003 05:37 PM
I know they can be bench tested, but I don't know the details. I can say that even a clean bench test doesn't mean that it is totally healthy...but it should be good for a work/no work answer.
RoninLB 12-20-2003 06:08 PM
Re: Bench-testing alternator
diodes are impact sensitive.. even a car crash may destroy a diode. I assume things haven't changed much in 30yrs concerning diodes. A quick diode check involved an ohm meter connected to alt output and the alt ground with wires disconnected from the car. I think the routine was less than 1k ohms for everything to be OK.. Sorry I haven't done the routine in years.. but any shop guy will know.....
Lorenfb 12-20-2003 06:26 PM
You really can't check the diodes that way. They are all (three at time)
connected basically in parallel because of the windings. Two of the
three could be bad and the resistance check would be O.K. The unit
really needs to be turned using a motor or a drill.
The D+ and B+ outputs need to be checked separately. Each is connected
to the DF and excited using a test light connected to 12 volts. Once
the alt. reaches about 600 rpms, the testlight will go out indicating
that all diodes are O.K. for that output (D+ or B+). If the light glows,
then a diode/diodes is/are bad.
Have Fun
Loren
'88 3.2
911pcars 12-21-2003 03:16 PM
To check diodes, you have to unsolder them to test them individually for one-way continuity.
A "bench test" at an electrical shop where they physically spin the alternator is probably a better suggestion.
Sherwood
http://members.rennlist.org/911pcars
KNS 03-22-2010 07:43 PM
Thanks guys, I'll find a proper shop.
KNS 03-22-2010 07:59 PM
Whoops! Responded to a seven year old thread.
James Brown 03-22-2010 11:28 PM
Take it to any shucks or napa and the'll check it out for free.
James Brown 03-22-2010 11:33 PM
Crap, me too!!
RWebb 03-23-2010 01:01 PM
never hurts to bump an informative thread
James Brown 03-23-2010 06:56 PM
Yes it will be asked again soon
shbop 03-23-2010 07:54 PM
..and a 944 pulley fits right on. jic :)
86 911 Targa 03-23-2010 10:36 PM
Originally Posted by 911pcars (Post 1086479)
to check diodes, you have to unsolder them to test them individually for one-way continuity.
Sherwood
Index
+1
