Senior Member
Bench-testing alternator
My alternator is out of the car and has suffered a small fall onto the back of the unit.
I would like to test it, or at least verify the integrity of the connections, before reinstalling it. Is there a way to do this? What tests and values should I look for among the connections if it is possible? Thanks, Olivier
Olivier Hecht 1982 911SC |
I know they can be bench tested, but I don't know the details. I can say that even a clean bench test doesn't mean that it is totally healthy...but it should be good for a work/no work answer.
Re: Bench-testing alternator
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
You really can't check the diodes that way. They are all (three at time)
connected basically in parallel because of the windings. Two of the three could be bad and the resistance check would be O.K. The unit really needs to be turned using a motor or a drill. The D+ and B+ outputs need to be checked separately. Each is connected to the DF and excited using a test light connected to 12 volts. Once the alt. reaches about 600 rpms, the testlight will go out indicating that all diodes are O.K. for that output (D+ or B+). If the light glows, then a diode/diodes is/are bad. Have Fun Loren '88 3.2
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone |
To check diodes, you have to unsolder them to test them individually for one-way continuity.
A "bench test" at an electrical shop where they physically spin the alternator is probably a better suggestion. Sherwood http://members.rennlist.org/911pcars |
Thanks guys, I'll find a proper shop.
Kurt |
Whoops! Responded to a seven year old thread.
Kurt |
Senior Advisor
Take it to any shucks or napa and the'll check it out for free.
08 Cayenne Turbo |
Senior Advisor
Crap, me too!!
08 Cayenne Turbo |
AutoBahned
never hurts to bump an informative thread
Senior Advisor
Yes it will be asked again soon
08 Cayenne Turbo |
..and a 944 pulley fits right on. jic
Jon |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
