I need new rear wheel bearings on 87
I need to replace my rear wheel bearings on the 87.
I am trying to decide if I should pull it all apart, have the bearings pressed out and in, put it back together and have the fresh alignment redone vs have the shop do the work with the hubs still on the car.
Is it possible to do it myself and retain the alignment settings?
Randy
'87 911 Targa
'17 Macan GTS
Old 12-22-2003, 02:50 PM
JTO JTO is offline
The rear alignment is not affected. I have done this job twice using the Sir Tool bearing remover/installer I got from Pelican. The job is made easier with this tool but still takes a while. You don't have to remove the swing arm,etc. You do have to remove the rear brakes, e-brake, etc.
Troy
Troy
Past: 1975 911S Silver Anniversary-rebuilt and sublime.
Past: 1988 Carrera-backdated with a 3.6 and all the goodies.
Present: 2011 GMC 2500HD with the 6.0 & 4x4!, 2004 Toyota Sequoia (wife's)
Old 12-22-2003, 03:03 PM
the SIR tool does not pull the flanges (hubs). you have to do that either by pounding from behind, which i don't like to do, or with two long prybars from the outside. the tool does reinstall the flange though.
206 637 4071
Old 12-22-2003, 03:07 PM
JTO JTO is offline
hey John,
Not to be contrary but I used the sir tool to pull my hubs. The bearing race came out with the the stub axle. i used a dremel to cut the race most of the way through. I then hit the cut with a screwdriver and hammer to break through the cut in the race the rest of the way. Maybe I'm talking about something different.
troy
Troy
Old 12-22-2003, 03:14 PM
I JUST REPLACED HALF SHAFTS, REAR WHEEL BEARINGS, INNER STUB SHAFT SEALS, CLEANED AND ADJUSTED REAR EM BRAKE, CLEANED THE TRANSAXLE AND REASSEMBLED EVERTHING WITH JUST THE PURCHASE OF THE HARBOR FREIGHT 3/4 METRIC DRIVE
SET. I SWEAR YOU GET THE MOST LBS PER DOLLAR OF SOCKETS WITH THEM. AND SOME SCRAP STEEL AND 5/8 ALL THREAD TO PULL THE BEARINGS BACK IN. i WELDED A 2" WIDE 1/4 STEEL STRAP ACROSS THE TOP OF A CAST IRON 3" GAS UNION TO USE AS THE PULLER. sAVED THOUSANDS COMPARED WITH TAKING IT TO THE DEALER. IF YOU NEED HELP MY MINE IS STILL FRESH ABOUT THE JOB EMAIL OR GIVE ME A CALL. 87 carrera
KEITH EPPERLY
1-316-733-8511
kepperly@sbcglobal.net
Old 12-23-2003, 01:15 PM
Well, can I add to this inquiry?
Anyway, I'm looking at my Porsche Parts and Tech ref. for the rear suspension and it has the following 3 parts...Axle bearing 999 053 020 01, inner bearing 999 059 047 00, outer bearing 999 059 056 00. I'm confused, which ones are the ones that "wear out" when rear bearings go bad? Is it all of them? I'm having a low rumble/whirring sound from the rear that is tied to speed. I need new tires badly (new ones on way from tire rack) so I'll find out if it's tire noise but am prepared for a bad bearing(s).
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 12-23-2003, 08:09 PM
MovOvr1's Avatar
I had mine replaced on a 79 930 and it was $900 with a completed replacement of the halfshaft and inner and outer wheel bearings. And this was at a DEALER. It was in and out in two days and no hassle (okay...except for the $900).
Brian
BLK 79-930
Old 12-23-2003, 10:32 PM
88911 I would bet your noise is tires, lots less hassal than going in for the bearings. If tires don't do it then go deep. My replacement took about two weeks, but thats two to three hours a night and Saturdays about 6 hours, plus I built the tools to do it and source the $4.00 worth of scrap to make the tools out of.
Keith
Old 12-24-2003, 10:50 AM
