This glove box rattle is driving me insane!!!
AAARGH!!! Drive with glove box open no noise, close it and it rattles like a freakin Camaro.
Anyone know how to make rattle go away and still have functional glove box? alf
88 Carrera Coupe Pelican Since 2002 All Zing, No Bling. ok, maybe a little bling. The Roach |
Have you tightened the large nut on the back of the latch? Mine comes loose all the time and the glove box rattles.
Don 24 Cayman GTS - GT Silver 23 Cayman GTS - Arctic Grey - Sold 97 993 Coupe - Arctic/Black - Sold 13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue |
My usual approach for anything that rattles is to whack it with a hammer a few times.
Dan Morissette '85 Guards Red Targa 911 My Owners Gallery Page Non illegitimi carborundum |
Or fold up a bit of papper and poke it in a gap somewhere. This method usually works with Toyota rattles - my SC doesn't rattle
I once met a guy that went so crazy with toyota rattles he filled all of the empty spaces between the interior panels and the body with 2 part foam. dont think it worked though
1967 912 2.7 1977 MGB (bright yellow) 1985 Honda Spree Moped (great for towing rollerbladers) A flute without holes, is not a flute. A donut without a hole, is a Danish. |
Autodidactic user
I've used the cheap 1/4 inch foam weather stripping, the kind with peel-off sticky tape on one side, on the inside edges of the door. It absorbes the rattles pretty well and can't be seen once installed. You can find this stuff at places like Lowes or Home Depot. Probably Wal-Mart too. Good luck and Merry Christmas.
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions. ![]() 1973 911E Targa (MFI) |
It's that Carrera death rattle. They all do that. Cause they wish they were an SC! Nah just kidding. If the large nut on the lock is not loose and the smaller fasteners at the bottom are not, then you need to add 2 small black rubber bumpers on the face of the dash where the lid meets it. You should have at least one, maybe two now unless they have fallen off. It will take a while to get these as they are special order, so you can buy some at most hardware stores that will work just as well. They are used as cushions under things or to keep cabinet doors from banging when they close. If you get ones that are too thin, you can stack them to achieve the desired result. Here is the Porsche part if you go that route:
RUBBER BUFFER OEM-99970333050 99970333050 $1.03
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
turn up the radio
78 911 SC "Scratchy" 2004 Mini Cooper S "Pele" (gone but not forgotten) 1979 classic mini clubman-"Coolio" |
Fixed it!
Stuck some felt to the top edge of the box door, especially on the right top corner. The 2 little rubber spacers on the glove box was worn and not keeping the metal on the door from rubbing on the metal of the box. alf happy.
I guess alf's well that ends well.
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
Bandwidth AbUser
Jim R. |
Alf, you could have solved it by putting on a sport muffler and SSI's
Harlan Chinn Pacific Northwest Region 1998 Carrera S ArcticSilverMetallic 1982 911SC PazificBlauMetallic |
