78-83 cdi box pinouts?
Would anyone by chance know the pinouts for a 78-83 bosch 6 pin cdi box? I know two wires must go to the (hall sensor)spelling?) Right now the two wires comming out of that sensor are not labeled. I have heard if I hook them up backwards it will burn it out. Is there any way to determine the correct wires from the hall sensor to the cdi box?
Thanks for reading this and any input will be greatly appreciated. Have a happy New Year!!!!!!!!!!!!
Matt
Old 12-28-2003, 01:33 PM
Okay I now know that the box is labeled as...
pin(1)31/1 pin(2)TD pin(3)31d
pin(4)A pin(5)15 pin(6)7
Can anyone tell me what each of these numbers represent?
Matt
Old 12-30-2003, 12:53 PM
Matt
Not sure if this answers your question but thought it might help
perma-tune shows the pin out. go to the technical support selection for your particular car.
http://www.perma-tune.com/Products/Ignition%20modules/Porsche/Porsche%20Products.htm
example of 911sc and 930 6 pin:
1 = System ground 4 = Not Used
2 = Tachometer signal 5 = Power
3 = Signal ground (distributor pin B) Green wire shield 6 = Signal (distributor pin A) Green wire center conductor
Old 12-30-2003, 05:22 PM
gadams,
Thank you very much this has been extremely helpful.
Old 12-30-2003, 06:33 PM
Early_S_Man's Avatar
Porsche Crest
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 12-30-2003, 08:17 PM
Senior Member
Superman's Avatar
Reversing these wires does nothing. doesn't even change the timing.
Mocha 1978 911SC. "Coco"
Old 12-30-2003, 09:43 PM
Lorenfb's Avatar
The wires from the distributor (reluctance magnetic pickup & not Hall) MUST
be oriented correctly or the ignition timing will be retarded. The CDI unit
senses the negative edge of the dist. signal to generate a spark. Reversing
the wires will result in a very poor running car.
Good Luck
Loren
'88 3.2
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 12-31-2003, 05:39 AM
