sammygon1's Avatar
Why did this happen?
I have the engine out to replace the flywheel. But before I put everything back together I though I'd ask if anyone knows why a flywheel would get eaten up so much. The teeth on the old one are just completed chewed up. Anyone have similar problems? Included is a pic. Oh I am using a new bosch starter as well, the teeth on the old one are worn down too. Thanks Sam
Old 12-30-2003, 08:42 AM
scottb's Avatar
Wow!
Looks like a question for JW.
1984 Targa
Old 12-30-2003, 08:47 AM
Friend of Warren
Some uneducated guesses: Starter not completly engaging or the starter engaged and wouldn't disengage while the engine was running.
Kurt V
Old 12-30-2003, 08:48 AM
Senior Member
Superman's Avatar
I agree that the "why" question is a good one for JW. In the meantime, I assume you know that your engine needs a new Ring Gear and the starter probably needs a nose gear replacement.
Mocha 1978 911SC. "Coco"
Old 12-30-2003, 08:53 AM
Unregistered
sammyg2's Avatar
Possible causes?
loose starter (seen that one before)
cranking and cranking way too long to try and start a messed up car (seen that too)
Damaged bendix that hangs up
Worn starter gear
Wrong starter/improper engagement
that's all I can think of right now
Old 12-30-2003, 08:59 AM
Doug E's Avatar
By the looks of that thing it is amazing that the car even started.
Was it like that all the way around or just on the section you show in the picture?
Doug
'81 SC Coupe
Old 12-30-2003, 04:39 PM
You do not have permissi
john70t's Avatar
Does the engine turn over easily by hand(too much torque required)?
Is the flywheel/transmission correct for the engine type(starter too close).
I'd agree with the guess that the last starter was not disengaging. It looks evenly chewed all the way around.
Old 12-30-2003, 05:00 PM
North Coast Cab's Avatar
What year car? On mine there is a starter ring, maybe it was missing and put undue pressure on the flywheel. Just a guess.
John
1985.5 944 GTS
Old 12-30-2003, 05:03 PM
sammygon1's Avatar
The engine turns over easily and runs very well. The flywheel and tranny are right for the car it is a '69 911. 2.0 and 901 trans. The teeth aren't messed up as badly all the way around (the picture shows the worst) at best though the teeth are about 3/4's there.
Sam Gonzales
'69 912 2.0 -6 power
Old 12-30-2003, 06:02 PM
pwd72s's Avatar
Well, somethin' shore as he!! ain't lined up right!
Old 12-30-2003, 06:25 PM
Early_S_Man's Avatar
Porsche Crest
Sam,
Let's see ... did the 'former' teeth of the ring gear reside at the bottom of the bellhousing as a neat little pile of shavings???
Maybe somebody bumped the starter switch (or a random switch failure) caused the starter to engage at 7000+ rpm?
ps ... Not a '69 trans or 'cup-type' flywheel, that would be a '70 or '71 version of the flywheel & pressure plate for the last '911' version of the 901 that used a pulley and Bowden cable sheath to do the actuation of the throwout bearing!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 12-30-2003, 06:54 PM
Make Bruins Great Again
Por_sha911's Avatar
I had a problem with chewed up ring gears. It turned out to be the starter wasn't shimmed properly (too close to the flywheel).
Joe
Old 12-30-2003, 07:14 PM
