3.6 transplant fuel pump question
The Carrera pump just pumped it's last drop. Should I try and fit a new 993 pump to match the 993 engine or just get another Carrera pump which seemed to work fine??
Get a blue 964 pump
PET shows 2 different numbers for all of the c2/c4 years, any idea which is the "blue" ?
964 620 104 00 964 608 102 02 |
Famous last words.. "Hold my beer and watch this...' " The reason the Irish are always fightin one another is that there are no other worthy opponents ". |
I used hte pump on hte SC, works fine. Anything with CIS up should provide enough fuel.
Isn't the SC pump a higher pressure pump than the 993 pump?
I'm still running my SC pump.
Yes, the CIS pumps are higher pressure( and I believe volume but that needs to be checked) but it's not an issue because of the fuel log pressiure regulator, excesss just goes back to the fuel tank.
