Air injector removal/bolt replacement question
Can't seem to find the thread I was looking for...
I'm removing my air-injector system on my '77 2.7.... Can anyone tell me what length bolt I should replace my air-injectors with? Should I use a particular grade of steel? Also, my EGR system was disconnected by the PO, and I finally removed the whole thing. Was wondering what kind of cap to place on the muffler where the EGR canister used to go. Thanks,
Kris - '77 911S |
When I did mine on my long ago departed SC, I used allen head set screws that were just about the length of the threads in the hole. I can't remember exactly, but they were about half an inch or so.
Hope this helps. Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Here in the UK, Type911 sells these:
http://www.type-911.co.uk/images/performance/plugs.jpg I guess you can get them in the USA somewhere.... Cheers, Tim.
1984 Carrera - 3.6 Conversion, 326bhp, 1020kg - SOLD 1987 930 - SOLD 1983 911 SC Targa - SOLD http://forums.pelicanparts.com/impactbumpers.com - Classic 911's and nothing else |
Irrationally exuberant
This Air Injection thread has pictures of the plugs.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Thanks!
Kris - '77 911S |
Kris
I removed mine recently and found that a convertor drain plug found on the automatic transmisson from a Mercedes Benz 450 SEL will fit pefectly. You can also order from the dealer the matching aluminium washer. It has a hex head and looks very original. Regards Todd |
The ones I used were exactly like the ones in Tim's link. Got them at the local metric fastner company for under 5 bucks.
Jeff
Sent you a PM.
Cymru am Byth
You can get them from Ted Robinson at German Precision in CA.
1986 930 (Gone but not forgotten) 1995 993 (Should Never Have Sold it) 2007 BMW 328Xi Sport Wagon 2005 Lexus GX470 Offroader Julian Williams |
Thanks Guys. Jim--sent you a couple of PM's.
Kris - '77 911S |
