Question Chain noise when warmed up???
I have a 74 911T with about 50K on rebuild. It has sat a fair amount the last couple of months. When I warmed it up the other day it sounded like I had a loose muffler and sound only happens at idle to 2600 rpm at which point it quits completely. Not really a sound I would describe as a chain on a garbage can, again more like a loose muffler. I went to check it out and have discovered this sound only occurs once engine is warmed up (gets progressively louder to a certain point). From what I have read bad tensioners sound is worse at cold start. It appears to be from chain tensioner cover area but using a stethoscope I can hear noise resonate back thru intake. Can these tensioners react this way when first going bad? Or should I be looking somewhere else. By the way, exhaust is fine, no leaks or loose areas. Sound is louder under left chain cover than right, but I can hear on both sides using stethoscope.
thanks
Old 01-04-2004, 08:07 PM
You don't say what kind of tensioners you have. If it were me and I heard a chain noise I would pop the covers and have a look. And hyd. tensioners can act that way
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 01-04-2004, 08:17 PM
This car has low miles, but the engine work was done over twenty years ago. I am sure they are the stock type tensionsers for the 74 (old hydraulic type)
Old 01-04-2004, 09:18 PM
Don't know if your 74 has an air pump, but the smog air check valve on my 76 gave me a scare with clattering noise. Close to chain cover. Easy to check with the stethoscope.
'76 2.7-->3.2
Old 01-07-2004, 12:58 PM
Ok thznks, will check
Old 01-07-2004, 03:40 PM
I'd continue to look around the exhaust cylinders ect....for source....if nothing, I'd remove the chain covers and take a look, make sure your familiar with all aspects of how the chain, tensioners and ramps work together. The most this will cost if not the source of the noise, is new oil and new chain cover gaskets....
72 Porsche 911T/E Targa
72 Porsche 911S
85 BMW 735i
Old 01-07-2004, 04:00 PM
Super Moderator
cstreit's Avatar
How exactly can you tell if a tensioner is failed by just looking at it?
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-07-2004, 05:32 PM
The two I have seen were quite obvious upon inpection (possibly due to the fact that they were both mechanical). One was not maintaining tension on chain (slack chain). The other had worn a groove where it was rubbing the housing when the chain went slack. This one had started to chew into a chain ramp as well.
hope this helps......
72 Porsche 911S
85 BMW 735i
Old 01-07-2004, 06:10 PM
