Malfunctioning Turn Signals
The turn signals on my 1973 911T work correctly only when the head lights or running lights are off. When I turn the head lights or the running lights on the signals will no longer flash, nor do I hear the clicking noise from the flasher. This problem was occuring before I replaced the turn signal stock, and flasher. Neither of which have solved my problem. Any suggestions would be great.
thanks
Brad
Old 01-11-2004, 02:02 PM
Banned
mine used to do this as well i cleaned the grounds that go from the tail lamp to the inner fenders and it fixed it.
give it a try
kyle
71` 911
Old 01-11-2004, 02:18 PM
Cool
sounds like a typical ground problem.. but it could be a harness connector problen
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-11-2004, 02:45 PM
3.2 CAB's Avatar
DITTO
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 01-11-2004, 02:50 PM
vash's Avatar
you know how all the wires (ok alot of the wires, not all of them) go through the headlight switch? how much do you think a new headlight switch will cost? i hate electical problems, so i tend to just change parts i would look into a new headlight switch, if it was inexpensive. keep us posted on this one please.
cliff
poof! gone
Old 01-11-2004, 04:45 PM
