scca_ita's Avatar
How to verify that there is/is not a LSD
in a trans that is not installed? (73 915 Trans)
The numbers are 7321142 if that matters or is there a factory indicator somewhere on the case?
Old 01-06-2004, 07:55 AM
targa911man's Avatar
Turn one of the cv's. If the other one turns in the same direction it's lsd. (I assume your acronym is for limited slip differential.)
Dan Morissette
'85 Guards Red Targa 911
My Owners Gallery Page
Non illegitimi carborundum
Old 01-06-2004, 08:08 AM
I should clarify that I meant if the other one turns in the same direction while you're turning the first one.
Dan Morissette
Old 01-06-2004, 09:49 AM
scca_ita's Avatar
Well mine turns the opposite direction so I guess there is no LSD......
Old 01-06-2004, 10:28 AM
Team California
speeder's Avatar
It must be in neutral, verify that the shifter rod is in the middle position, fore/aft.
Denis
“When Trump is gone, what people will remember is the cowardice of those who went along.”
Old 01-06-2004, 10:45 AM
Lick it..
James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood.
Ayrton Senna
1993 964 RS
Old 01-06-2004, 10:51 AM
Grady Clay's Avatar
Not necessairly so.
The LSD in a 915 is just that - limited. When there is sufficient torque applied theough the diffrerntial then the two side gears are forced together and the clutches tend to engage. If the clutches are set "soft" or have many street miles at all then the "turn the axle-flange" test won't work. It acts just like a regular differential.
Take the far side axle-flange off, undo the side plate and look. A LSD has a machined and welded cylinderical housing. A regular differential has a semi-spherical cast housing. Obvious difference.
When I use a LSD, I set it up so it takes a large wrench to get the two axle-flanges to turn in different directions. The car is much more stable in transition from trailing throttle oversteer to power oversteer and back to neutral handling by apex and out of a corner.
If this is for a race car, have a welding pro weld a stock differential solid. This should be done with the axle-flanges torqued in place and by someone who knows how to weld alloy steel to cast steel. The ring gear and bearings should be reboved and the entire assembly heated appororiately.
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 01-06-2004, 10:53 AM
304065's Avatar
Lick it..
I tried that. Nothing happened.
I think I have gotten "burned!" And the trans is out of a '68!
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 01-06-2004, 11:25 AM
Grady Clay's Avatar
John,
If it is a ’68 then it has an aluminum case and is a 901 trans. The magnesium case 911 trans came out in mid ’69 but if you ordered a LSD you got the alu case. The LSD for ’70-’71 911 trans is the same as 915 I think. Of course 915s came out with the ’72 model year. You will find different P/Ns depending on the LSD clutch set-up.
In addition to a serial number, most transmissions have a type number also. If it is a early trans it will have a 901/?? type number. If a 915 it will say 915/??
Don’t despair, the 901 trans will find a nice home in someone (else) early 911.
When you buy transmissions that are out of the car, it is easy to partially dissemble and inspect, no special tools needed. If you know what to look for, most problems are obvious.
Old 01-06-2004, 11:55 AM
