Spark Plugs and Wires
I am looking at getting Magnecor wires and NGK plug wires.
What size wires should I get? Is there a specific model spark plug. I am sure there is a number for my motor, but sometimes what the manufactor doesn't suggest what is truly best or has been proven best. - Brett Smith 1988 3.2
1971 Porsche 914 1988 3.2 Carrera motor 930 Brakes / Suspension Upgrade Autothority Chip and MFS |
8.5 wires are popular
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
and I use BPR6ES NGK plugs in my '88 engine - albeit with 10.3 compression...
Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
Friend of Warren
'86 Carrera with the Magnecor 8.5's and NGK BPR6ES plugs.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Gon fix it with me hammer
i'm running 8.5's
EDIT Magnecor's
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 Last edited by svandamme; 01-07-2004 at 11:14 AM.. |
Suggest for an '83, BERU plug wires and w5DC. We feel the quality of BERU's are worth the extra $. Have been in business for 25 years working exclusively on Porsche's and would only recommend using these wires.
I've had good results with carbon core ignition cables and would stay away from Beru as most of my ignition problems I have had in the past have been traced to bad Beru connectors or shorting cables.
Joe |
Do you have to pull the AC compressor out to route the wires below it?
Thanks guys.
