future master cyl nstalls & cluster rebuilders.
ok i just finished installing a new MC, rebuilt the pedcluster, installed new lines, and rebuilt the calipers. it wasnt totally hard. the mistakes i made? for one, i destroyed my brakelight switch. i took it for granted because it looked like the easiest part to take off. it was, i just forgot how it went back on. i installed it with the switch arm above the MC piston pusher rod. and when i lifted the plunger arm to stick it into the MC, CRACK!. oh well, i found a used one for $5. i went around the car bleeding the brakes like a man possesed. after i was done, and things were still spongy, i found two leaks. damn, look for leaks after the first go around.
other than that, piece o cake thank to you guys and 101 proj. i will rebleed tomorrow, and button it up. let you know how it goes. cliff (thanks makaio)
poof! gone |
Good to hear you got it done. Where did you find the leaks? I still seem to have a stubborn leak where the resorvoir supply line attaches to the MC (where the plastic fitting presses into the rubber bung).
cliff
poof! gone |
oh yea, it helped to scream from the abdomen while pulling the lines into the grommets. you know, harness your inner "CHI"
![]() (it worked for bruce lee when he was whuppin up on some villian)
poof! gone |
I left the rubber grommets in the MC & pushed the plastic fittings in w/ everything bolted up. I might see if I can get them more firmly seated w/ a piece of wood dowel or something for leverage.
I'm hovering over the front trunk w/ the wounded praying mantis pose at this moment. Maybe this will psyche those bad lines out. |
that is so funny! wounded praying mantis?!!! good luck
poof! gone |
I Just sent you a PM regarding this, becasue I didn't see the post initialy.
Glad it worked out for you. |
