OkieRon's Avatar
Question Disable MFI Cold Start?
I am replacing the "sat for 14 years" fuel lines. A local wrench told me that in the 70's Porshce directed owners to disable the cold start fuel pump and lines on MFI due to possible fire hazard. Is this correct or possible and how do I do it?
Ron
Old 01-09-2004, 09:39 AM
Friend of Warren
Ron he may have been referring to the early MFI cold start which had the cold start injector shooting gas into the air filter housing and yes that damn thing could catch on fire. The later cold start lines run into the base of the throttle bodies and there is no problem with these. Easy to tell which one you have just by looking.
Kurt V
Old 01-09-2004, 10:59 AM
OkieRon's Avatar
Thanks Kurt,
I have a 72T. The MFI has the lines running along the side with "T"'s going into the side of the MFI housing. Would this be the later or earlier style (considering its a 72' I would guess the latter)
Thanks Ron
Old 01-09-2004, 11:11 AM
304065's Avatar
Later style. I disabled the old school "pisser" in the airbox, that's a fire waiting to happen. One of these days I'll fab up a squirter in the stack like the plastick stack type.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 01-09-2004, 12:40 PM
Warren Hall Student
Bobboloo's Avatar
As John said you have the later style, no problem. Just make sure the the hoses going to the stacks aren't cracked and dried out.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 01-09-2004, 01:46 PM
OkieRon's Avatar
Unfortunately they are cracked and dried out. Worst of all, several of the plastic "T"'s are missing. Any thoughts on a replacement as I heard they are nearly impossible to find?
Thanks Ron
Old 01-09-2004, 05:17 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
My 69S doesn't have the squirters...it does have the solenoid on top of the filter assy...but no lines coming off and no wires.
What I do have is the enrichment solenoid on the MFI pump.
I have this hooked up to a separate switch so that I have control of the amount of fuel being enrichened on start.
Seems to work even in the extreme cold (0 deg C) and only needs to shoot extra fuel for about 5 - 10 seconds.
Bob
Bob Hutson
Old 01-09-2004, 05:21 PM
OkieRon's Avatar
More to the point. . . Is it possible to disengage the LATER STYLE cold start apparatus on the MFI. Can it be run without the cold start lines (as it would be with the earlier style disengaged) or is it necessary or prudent to use it. If not, how do you disengage the cold start pump so that gas isn't spewing all over the MFI. Thanks Ron
Old 01-09-2004, 05:28 PM
pwd72s's Avatar
Thanks Ron
I've never done this personally, and it would not be "original"...but I've often wondered if the metal T's made out of chrome plated brass as sold in aquarium shops as air line T's would work. The diameter is close...
Old 01-09-2004, 05:46 PM
If I'm not mistaken, the "T" fittings have an oriface that distributes a spray pattern, rather than just dumping fuel into the TB's.
I was able to find a couple of replacements at a P-car salvage yard a few years ago; I think it was Best Deal or EASY, but I can't be certain.
Oh yeah, WHY did i need replacements?
What he said. It's also a good idea to make sure your spark plug wires aren't so old that they're arcing inside the engine compartment.
This happened during the first week of 911 ownership for me. I hope I'm a bit wiser now.
Jim
Old 01-09-2004, 06:33 PM
Warren Hall Student
Bobboloo's Avatar
To unhook the cold start on a 2.4 all you do is unplug the wire from the top of the fuel regulator (console that mounts to the chassis) that the filter screws on to.
Nearly impossible unless you hang out here.
How many do you need?
Bobby
Old 01-09-2004, 06:51 PM
OkieRon's Avatar
I need two.
Old 01-09-2004, 09:56 PM
Warren Hall Student
Bobboloo's Avatar
Email me your address at ginsburg@lanset.com and I'll drop you two in the mail.
Bobby
Old 01-09-2004, 10:25 PM
sithot's Avatar
Re: Disable MFI Cold Start?
Ron
Correct quote. Porsche DID direct owners to do this.
Tom
R Gruppe #111
Early S Registry #235
res ipsa loquitur
Old 01-09-2004, 11:17 PM
