-   -   rear view mirror glue (http://forums.pelicanparts.com/porsche-911-technical-forum/143238-rear-view-mirror-glue.html)
vash 01-09-2004 09:33 PM
something strangely entertaining when a mirror falls off. today, during my windex binge on the front window, i knocked my mirror off. i need some uber glue to get it back on. the stuff at the auto parts store any good?
cliff
Por_sha911 01-09-2004 10:16 PM
The specialty glue for rearview mirrors (sold at the basic auto parts place) works great IF you clean everything with rubbing alcohol, let it dry, and follow instructions to the letter. I've had to replace several mirrors over the years and the glue works great.
vash 01-09-2004 10:19 PM
oh god, i have to follow directions?
thanks joe! looks like i have an easy car day tomorrow.
grant lyon 01-10-2004 12:27 AM
Elmer "Stix-All" Reorder No. E-650, Ace Hardware type stuff will do the deed. Maybe not quite a strong as the specialty glue, but good enough if you're not rough-housing. Regardless, cleanliness is key. Mark outside of windshield where you had the mirror base (or adjusted to your preference, including checking visor clearance). Purpose: install with glue and let set without disturbing the bond.
Victor 01-10-2004 01:16 AM
I bashed mine off twice with my helmet (have a big head). Loctite make a two part glue specifically for rear view mirrors. Have no knocked it off since.
RoninLB 01-10-2004 04:59 AM
Re: rear view mirror glue
my car has a stock glued "sticker" that fits between the mirror and shield. I always use a heat gun to warm up the glass, mirror mount, and "sticker".. and I keep extra "stickers" around
limble 01-10-2004 05:55 AM
I tried the stuff from auto parts store when I replaced my windshield it worked for me. However the color wasn't the same as the original. Concours guys might have had a fit.
Scooter 01-10-2004 06:37 AM
My mirror fell off months ago, but I haven't put it back on, because I like the clear front view without it. I have found that the two side mirrors give me all the rear view that I need. Anyone else out there driving rearview mirrorless?
tmctguer 01-10-2004 09:07 AM
i drove w/o a rear view mirror for a few weeks last year, and i really did not like it. i did not feel safe backing up, and i did not like not knowing what was behind me. i have a '73 which only has a driver's side mirror, so i was not seeing much. i also have a race seat which somewhat limits my side-to-side body movements, so it was not easy to turn around to get views.
i too, used the rear view mirror glue found at your LAPS (local auto parts store) and it worked fine. however, i'll mirror (tee hee) the view expressed earlier that you MUST thoroughly clean the old glue off the glass. i used a combination razor blade and alcohol to get it all off.
pwd72s 01-10-2004 09:22 AM
"What's behind me doesn't matter!" -Character played by Raul Julia in one of those corny "cannonball" flicks...said as he ripped the rear view mirror from a Ferrari. :D
Por_sha911 01-10-2004 09:27 AM
Originally posted by tmctguer
...i'll mirror (tee hee) the view expressed earlier that you MUST thoroughly clean the old glue off the glass. i used a combination razor blade and alcohol to get it all off.
Good point: Its been a while since I've replace a mirror but you are right about using a razor to clean off the old glue first. BTW, I'm giving your pun glassy-eyed stare.
vash 01-10-2004 09:58 AM
i think i will have a hard time cleaning the foot of the mirror. i think i had that factory sticky pad.
