-   -   What is a compression point worth? (http://forums.pelicanparts.com/porsche-911-technical-forum/143619-what-compression-point-worth.html)
dd74 01-12-2004 02:03 PM
Given all things equal in two 3.0 engines, what do any of you guess would be the horsepower difference if one engine had stock 8.5:1 compression, and the other stock 9.3:1 or maybe something like JE Pistons at 9.5:1?
Thanks.
kstylianos 01-12-2004 02:05 PM
Approximate HP increase per compression point is 10%/point.
Tyson Schmidt 01-12-2004 04:26 PM
I've heard more like 3% per point. But it is a parabolic curve. The higher you go, the lower the gains. Diminishing returns, as they say.
69911e 01-12-2004 04:50 PM
Here is the formula from a past link for 2 points increase.
theoretical thermal efficiency n(rc) = 1-(1/rc)^0.4 (See curve above)
Then:
8.5:1 gives n=57.5%
10.5:1 gives n=61.0%
making for a theoretical jump of ~6% (180HP -> 191HP with 6%)
Here is the link.
http://forums.pelicanparts.com/porsche-911-technical-forum/86453-effects-higher-cr.html
nostatic 01-12-2004 04:51 PM
I believe you're thinking of a logarithmic curve, but it depends on what you're plotting. If you're doing hp (y axis) v. cr (x-axis), maybe it would look like this:
http://soil-physics.nmsu.edu/sp/tuto...cs/log_plt.gif
But then again, would hp start to drop if you kept increasing cr? So maybe it would start back down...
Wayne 962 01-12-2004 04:56 PM
Just do a comparison of some older 911 engines. Some models had varying compression ratios with all other components being nearly the same. That will give you a good baseline to start with...
-Wayne
Bill Verburg 01-12-2004 06:08 PM
Here are the curves for a 3.2 published by Bruce Anderson.
http://forums.pelicanparts.com/uploa...1073959694.jpg
Tim Walsh 01-12-2004 06:36 PM
very interesting.. I'm thinking of upgrading my ~9.0:1 2.4E to 10.5:1 and twin plugs. So in reality it should only make another 10-12HP out of it?
