drag racing the short bus
dd74's Avatar
What is a compression point worth?
Given all things equal in two 3.0 engines, what do any of you guess would be the horsepower difference if one engine had stock 8.5:1 compression, and the other stock 9.3:1 or maybe something like JE Pistons at 9.5:1?
Thanks.
The Terror of Tiny Town
Old 01-12-2004, 02:03 PM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
Approximate HP increase per compression point is 10%/point.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 01-12-2004, 02:05 PM
PRO Motorsports
Tyson Schmidt's Avatar
I've heard more like 3% per point. But it is a parabolic curve. The higher you go, the lower the gains. Diminishing returns, as they say.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 01-12-2004, 04:26 PM
Here is the formula from a past link for 2 points increase.
theoretical thermal efficiency n(rc) = 1-(1/rc)^0.4 (See curve above)
Then:
8.5:1 gives n=57.5%
10.5:1 gives n=61.0%
making for a theoretical jump of ~6% (180HP -> 191HP with 6%)
Here is the link.
The effects of higher CR
'69 911E 2.7MFI ;996TT;987.2 CaymanS
'71 Volvo P1800E wife's; AMG SLK wife's
'71 Volvo race car
944S; 986S ; 734WHP drift car (son's)
Old 01-12-2004, 04:50 PM
nostatic's Avatar
I believe you're thinking of a logarithmic curve, but it depends on what you're plotting. If you're doing hp (y axis) v. cr (x-axis), maybe it would look like this:
But then again, would hp start to drop if you kept increasing cr? So maybe it would start back down...
Old 01-12-2004, 04:51 PM
Author of "101 Projects"
Wayne 962's Avatar
Just do a comparison of some older 911 engines. Some models had varying compression ratios with all other components being nearly the same. That will give you a good baseline to start with...
-Wayne
Old 01-12-2004, 04:56 PM
Bill Verburg's Avatar
Here are the curves for a 3.2 published by Bruce Anderson.
Bill Verburg
Old 01-12-2004, 06:08 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
very interesting.. I'm thinking of upgrading my ~9.0:1 2.4E to 10.5:1 and twin plugs. So in reality it should only make another 10-12HP out of it?
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 01-12-2004, 06:36 PM
