Porsche Crest 77' 915 question swing arm hard to move
why is the swing arm so hard to move ?? must I R & R the shaft to solve it ..Thanks Frank
Old 01-11-2004, 08:49 PM
It is twisting a torsion bar which is the rear suspension "spring element" that carries most of the weight on that wheel. What are you trying to do? Why do you want to move the swing arm? Jim
Old 01-11-2004, 08:55 PM
Iam sorry Jim,..I meant the arm that moves the T/O brg inside the tranny,..its on a bench (trying to clean it up) and I noticed it does not move very freely takes a bit of force to operate...TIA Frank
Old 01-11-2004, 09:12 PM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
if the tranny is by itself, the arm should move freely...at least mine did (1975 915). All the resistance could be explained if the fork is still grabbing the T/O bearing.
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 01-11-2004, 11:07 PM
No its not attached to any thing,.Maybe its just old thick grease I guess I shall R & R it to find out.. Thanks alot guys .. Frank
Old 01-12-2004, 07:36 AM
The 1977 915's have a helper or auxilliary spring( it has an "Omega shape") on the clutch release lever. Have you disconnected this helper spring? Jim
Old 01-12-2004, 06:13 PM
No Jim,..I have not..but when I work the fork,..It did NOT seem to action that part,..Hmmm maybe some Internal presure ??? Thanks Frank
Old 01-13-2004, 07:13 AM
