Limbo
PCA G stock racing question
I have an 79 SC that I am going to setup for G stock PCA racing and the previous owner ran the brake ducting from the front bumper, through the front trunk panel and then through the strut box's to the rotors. He did this instead of having the brake ducting hanging under the car.
Is this legal for G or F stock? The rules state that brake ducts are free but doesn't say anything about the routing path????? Help???
Big ol built Duramax Durango R/T 19’ Current Custom project V8 M3 08’ Built and spoiled |
I could easily be wrong but I believe that this section disallows that ducting setup in stock classes
6. Body/Chassis/Interior A. Removal or substitution of components, other than those specifically indicated below, is not allowed. B. Chassis/body, with the exception of bumpers and spoilers, must be the same material and configuration as supplied by the factory. Sheet metal modifications in the rear deck, trunk, and spare tire compartment as required for installation of a fuel cell are allowed.
Limbo
HI Bill,
What section of the rule book did you find this in? And thanks a bunch for the info.....
