CHILI's Avatar
72 911 Oil Tank capacity
I was helping a buddy work on his 911 this weekend and was dumbfounded by what he said "72's take 9 quarts of oil."
Is this correct? I did see on his gauge that it has qt quantities and full was a "9." I thought all 911's took 11 qts???? I know the 72 had the external flap and the tank in a different location, but is it smaller, too? Or do the smaller displacement motors (2.0-2.4) just hold less oil?
Signed,
Totally Confused
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please
Chad aka "Chili"
1974 Base coupe in Carrera outfit.
No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.)
My car http://www.pelicanparts.com/gallery/CHILI
1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras.
Old 01-12-2004, 10:30 AM
Bill Verburg's Avatar
Oil tank thread 1
Oil tank thread 2
Bill Verburg
Old 01-12-2004, 12:31 PM
Cool
My 72 911E takes about 8.5 quarts of oil,
With no front oil cooler, thats all they hold.
The oil line to cam tower restrictors in my
engine are upgraded to the Turbo type.
This is a great, inexpensive, and easy to
install upgrade for older 911s. Higher
oil pressure less oil foaming and more
accurate oil level readings.
Hope this answers your question.
Old 01-12-2004, 08:58 PM
PRO Motorsports
Tyson Schmidt's Avatar
With an oil change, the '71 and earlier cars took 9.5 quarts, the '72 took 8.5 quarts, and the '73 and later took 10 quarts.
So yes, the '72 tank is smaller by 1.5 quarts than the later cars.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 01-12-2004, 09:48 PM
CHILI's Avatar
Yep, that answers my question. Man, I would have dumped 10.5 quarts into it if I were the one doing the work. Good thing I was just there for moral support and a knowledge base. Great knowledge base, huh? Don't even know how much oil it holds. Hehehe.
Chad aka "Chili"
Old 01-12-2004, 10:26 PM
Randy Webb's Avatar
ANd just for a fun tidbit, the '73 oil tank weighs 8.6 lbs. with hardware but w/o cap, rubber buffer, or the Al oil filter mount, or filter.
So that is the min. wt. that was moved to the in front of the wheel position in the 72's.
Old 01-13-2004, 02:02 PM
Dry weight or wet wt?
Old 01-13-2004, 07:29 PM
Randy Webb's Avatar
Dry.
The next question is how much oil normally remians in tank while the engine is running.
Old 01-13-2004, 08:51 PM
PRO Motorsports
About 4.5 quarts.
But hey, I'd give my eye teeth to save just the 8.5# of weight from behind the rear wheels. But not everyone will notice such things. To me though, I sweat every ounce. Mind the ounces, and the pounds will take care of themselves.
2004 GT3
Old 01-14-2004, 12:37 AM
Randy Webb's Avatar
You want an Al oil tank in front or in front of the rear wheel (so do I but I don't want to pay for it).
The wt. will be a bit more with the filter & mount and some oil in it. Someday I may calculate the moment arms from the CG....
Old 01-14-2004, 03:41 PM
Why not just move the location of the tank to the smugglers box in the trunk? If built properly and insulated, no heat or smell will come in the cabin. Better wt distribution than 72.
Old 01-14-2004, 06:17 PM
