Super Moderator
How do I adjust Koni 80k-2088 shocks?
I have a set of Koni 80K-2088 orange shocks on the rear of the racecar. I took them out today and one of them has virtually no compression damping at all (compared to the other side).
They are apparently adjustable, but I see no where to adjust it. I tried turning the steel rod but even after 20-30 turns counter clockwise, they don't get any stiffer. I tried going back just as far past the origin point and still no dice... Looking on Koni's website showed several adjustment methods, but non that seem to fit these shocks! Thanks
Navin Johnson
I believe you have to compress the shock,engage the valve, then turn and adjust.
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Yep what Tim said. Or if you have the low pressure gas type then you have to press down on a ball bering looking thing that sticks up from the base where the piston shaft goes into the shock. Or more simply where the little rubber dust seal is. Hope this helps.
_____________________________ Clint Smith www.RebelRacingProducts.com 1970 911T ----> RGruppe RS/R (mexico blue) 1995 993 becoming an RS (gran prix white) |
Super Moderator
Tim... Engage the valve?
Where is this valve? I see no valve or screw of any sort! Chris
Super Moderator
Never mind, I got it. Pushed it all the way down and felt it engage the valve. 2 turns either way. Runner bumpers were getting in the way of pushing it all the way down.
Adjustability is in rebound only, not compression. Are these normally a lot harder in rebound than compression?
If you have no compression damping, it won't help. I believe that single adjustable konis adjust the rebound only
Regards, Jerry Kroeger
82 911SC Targa (05 Boxster S ) gone, but not forgotten 87 Suzuki GSXR-1100 1953 MG TD Mk II |
Super Moderator
Yep. Figured that out.
Turns out the DO have compression damping, it's just a lot softer than I "expected" it to be
Rebound damping is going to be 3 or 4 times as great as the compression damping.
Jerry Kroeger
Super Moderator
That it is.
![]() Makes sense really, the objective is to slow down the spring "release" THanks.
