How is compression ratio measured?
This may sound like a really dumb question, but I've never really thought about it before.
I know how you can theoretically calculate compression ration, but how is it actually/physically measured? |
It's the ratio of cylinder volumes, calculated with the piston fully down (BDC)
to it at TDC.
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone |
Super Moderator
THere is a comprehensive article on how to measure and calculate that in Bruce Andersons Porsche Performance Handbook. Worth buying if you don't have it!
Original Owner
Is this a trick question???
tsuter 78 911SC Turbo Targa Thaaaats Right!! |
Banned
Irrationally exuberant
Have you looked at that page? It doesn't look like it would work for anything but flat topped pistons. Am I missing something? -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Re: How is compression ratio measured?
-Chris
domed pistons deck height volume requires a built up "plate" that covers the dome at TDC.. The head gasket CCs can be measured mathmetically. I never attempted to do any of this.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
![]() -Chris
Here's a better calculator: Bruce Bowlings compression ratio calculator
-Chris
Thats a cool burette have had no luck w medical supply stores any suggestions where i can buy a burette???
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug 1984 Mercedes 500 SEC 1991 Mercedes 420 SEL 1992 Ford F-350 Dually 28' Pace Trailer |
Medical suppliers will have scissors, scalpels and slippers....
On a whim I went to yahoo under lab supplies: http://dir.yahoo.com/Business_and_Economy/Business_to_Business/Scientific/Supplies_and_Equipment/Laboratory_Equipment/Glassware/ Thanks a lot, now I have an urge to spend more money ![]() BTW: a flat sheet of tempered glass w/ a fill hole is normally used to help control the miniscus when cc'ing heads. Last edited by thabaer; 01-16-2004 at 08:11 AM.. |
-Chris
Yes, plexi.
If anyone didn't pick up how it's done, here's an overview: For simple shapes (perfect cylinder) you can just measure radius and length and calculate. Fo more complex shapes, you fill the volume with a liquid (colored ATF is good) and measure the amount of liquid. A burette is a graduated cylinder with a stopcock that can accurately measure varying amounts of liquids over a range of volumes. You will need to approximate the volume first, then buy a burette that will cover that range. Also you need a burette holder and stand. See procedures above and various hot rod books for how to do this, such as How to Hotrod VW Engines. |
