How is compression ratio measured?
This may sound like a really dumb question, but I've never really thought about it before.
I know how you can theoretically calculate compression ration, but how is it actually/physically measured? |
It's the ratio of cylinder volumes, calculated with the piston fully down (BDC)
to it at TDC. |
THere is a comprehensive article on how to measure and calculate that in Bruce Andersons Porsche Performance Handbook. Worth buying if you don't have it!
Is this a trick question???
Have you looked at that page? It doesn't look like it would work for anything but flat topped pistons. Am I missing something? -Chris |
Re: How is compression ratio measured?
-Chris |
domed pistons deck height volume requires a built up "plate" that covers the dome at TDC.. The head gasket CCs can be measured mathmetically. I never attempted to do any of this.
http://forums.pelicanparts.com/uploa...1074089274.jpg http://forums.pelicanparts.com/uploa...1074089513.jpg -Chris |
Here's a better calculator: Bruce Bowlings compression ratio calculator
-Chris |
Thats a cool burette have had no luck w medical supply stores any suggestions where i can buy a burette???
Medical suppliers will have scissors, scalpels and slippers....
On a whim I went to yahoo under lab supplies: http://dir.yahoo.com/Business_and_Economy/Business_to_Business/Scientific/Supplies_and_Equipment/Laboratory_Equipment/Glassware/ Thanks a lot, now I have an urge to spend more money :D BTW: a flat sheet of tempered glass w/ a fill hole is normally used to help control the miniscus when cc'ing heads. |
-Chris |
Yes, plexi.
If anyone didn't pick up how it's done, here's an overview: For simple shapes (perfect cylinder) you can just measure radius and length and calculate. Fo more complex shapes, you fill the volume with a liquid (colored ATF is good) and measure the amount of liquid. A burette is a graduated cylinder with a stopcock that can accurately measure varying amounts of liquids over a range of volumes. You will need to approximate the volume first, then buy a burette that will cover that range. Also you need a burette holder and stand. See procedures above and various hot rod books for how to do this, such as How to Hotrod VW Engines. |
| All times are GMT -8. The time now is 07:07 PM. |
