Send a message via AIM to Fahrvergnuugen
How is compression ratio measured?
This may sound like a really dumb question, but I've never really thought about it before.
I know how you can theoretically calculate compression ration, but how is it actually/physically measured?
Old 01-13-2004, 06:56 PM
Lorenfb's Avatar
It's the ratio of cylinder volumes, calculated with the piston fully down (BDC)
to it at TDC.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 01-13-2004, 07:40 PM
Super Moderator
cstreit's Avatar
THere is a comprehensive article on how to measure and calculate that in Bruce Andersons Porsche Performance Handbook. Worth buying if you don't have it!
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-13-2004, 07:44 PM
Original Owner
tsuter's Avatar
Is this a trick question???
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 01-13-2004, 07:46 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
http://www.aircooled.net/gnrlsite/resource/specgeninfo/calcs.htm
Old 01-13-2004, 08:06 PM
Irrationally exuberant
ChrisBennet's Avatar
Steve,
Have you looked at that page? It doesn't look like it would work for anything but flat topped pistons. Am I missing something?
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 01-13-2004, 08:49 PM
Re: How is compression ratio measured?
You use burette to fill the head or whatever you're trying to measure with a precisely measured amount of liquid. With a burette and a way to accurately measure depth, you can calculate the volumes and arrive at the compression ratio using Loren's (excellent BTW) definition. For pistons with a flat area around the outside you can measure deck height much easier than using the Jo block method.
-Chris
Old 01-13-2004, 09:12 PM
Cool
domed pistons deck height volume requires a built up "plate" that covers the dome at TDC.. The head gasket CCs can be measured mathmetically. I never attempted to do any of this.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-14-2004, 04:46 AM
To get the piston dome volume I put the top ring on a piston (with a little Vaseline to seal the ring gap) and push it to the top of the cylinder and then fill the cylinder to the top. I subtract the amount of fluid required from the calculated volume for the flat topped piston to get the volume of the dome.
-Chris
Old 01-14-2004, 06:14 AM
Here's a better calculator: Bruce Bowlings compression ratio calculator
-Chris
Old 01-16-2004, 04:47 AM
126coupe's Avatar
Thats a cool burette have had no luck w medical supply stores any suggestions where i can buy a burette???
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 01-16-2004, 08:26 AM
Medical suppliers will have scissors, scalpels and slippers....
On a whim I went to yahoo under lab supplies:
http://dir.yahoo.com/Business_and_Economy/Business_to_Business/Scientific/Supplies_and_Equipment/Laboratory_Equipment/Glassware/
Thanks a lot, now I have an urge to spend more money
BTW: a flat sheet of tempered glass w/ a fill hole is normally used to help control the miniscus when cc'ing heads.
Charlie Baer
'79 Euro 911SC (Guards Red)
'83 Quattro (Mars Red)
Old 01-16-2004, 09:08 AM
Use a piece of plexiglas. It's much easier to drill the hole and cut it to fit the head's (recessed) sealing surface.
-Chris
Old 01-16-2004, 10:27 AM
Randy Webb's Avatar
Yes, plexi.
If anyone didn't pick up how it's done, here's an overview:
For simple shapes (perfect cylinder) you can just measure radius and length and calculate.
Fo more complex shapes, you fill the volume with a liquid (colored ATF is good) and measure the amount of liquid. A burette is a graduated cylinder with a stopcock that can accurately measure varying amounts of liquids over a range of volumes. You will need to approximate the volume first, then buy a burette that will cover that range. Also you need a burette holder and stand. See procedures above and various hot rod books for how to do this, such as How to Hotrod VW Engines.
Old 01-16-2004, 12:00 PM
