Por 15 on galvanized steel?
The Por 15 instructions say don't use it on galvanized.
Has anyone gone ahead and used it anyway? Or perhaps by mistake without reading the instructions? Should I use 95% zinc rich paint instead? |
I just used on mine last week . I guess I should go read the can again.
Jim
77S 04 Titan 03 Xterra |
Yeah, well the type on my can is so small I can't even read it. I only know because they sent an instruction sheet.
I was hoping to find someone who screwed up about a year ago! I'll call the manufacturer on Tuesday and post their relpy. They seem to have a lot of restrictions, like you can't shake the product only stir it "like a good martini"! |
OK It seems I'm wrong, again. I just re-read their "Instructions for people who don't read directions" and you can use it on galvanized, but...you need to use thier Metal Ready Primer first.
Sorry for wasting the bandwidth! |
i did the entire inside of my 77. you will need the metal ready to make it stick. it has been on for over a year with now problems.
silver base coat white top coat
Jim R Gruppe Member once upon a time when you could run generators in Cambria to fix the cars and hit 150+ mph on the fun run "Alles ist gut" 2011 997 GTS "Orange Pepper Wagon" 2009 Cayenne GTS |
thats really nice.. was the topcoat also Por ? I've been a big Por fan for over 8yrs.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Droool!
that is nice. A full strip an por of my 74 is on my long term project list....
Current: 07 S4 Avant, 06 Volvo S60R Sold: '74 911, 01 986, 93 Volvo 240 |
Heck, I’m only 5 not 71!
Judt did the chassis with two coats of POR-15. You do need to use the metal prep first. You can shoot your favorite primer 45 min after the second coat of POR-15. this will allow the primer to bond with POR-15 as it dries. You do not have to use the tri-coat primer they sell. This info is from the POR-15 tech support.
Pat Henry Targa80 1980SC Targa (Mocha Brown) |
i did use the por topkote and to clearify after i used a wire cup on my grinder to take the inside down to bare metal i used the por metal ready to prep the surface.
for some perspective i had about 70-80 hours in prep and the painting took me about 20 hours. i did 3 coats of the silver and about 4-5 of the white to get the white to cover. if i had did it again i would mask everythign really well and spray as i think it would not take so long to paint.
