...or in other words:" Would you put those on an engine ever again or just make nice table art out of them?!?!" I couldn't belive I was looking at my heads when he was done with'em. He did replace all guides and springs and did a full valve job but these are my old valves
![]() ![]() ![]() ![]() ![]() ![]() ![]() considering they looked like this when they entered his shop in Lake Isabella a couple of weeks ago: ![]() ![]() Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
What a job!!!! Too bad you have to put them back in the car.
Neil '73 911S targa |
Those are beautiful.
But what did I miss? Why did you pull the heads on your 3.6?
Chuck Moreland - elephantracing.com - vonnen.com |
Chuck, the answer is in the "before pictures". Head to cylinder leak times six bad. Walt is going to cut a groove for a head gasket into the barrels to take care of that.
Author of "101 Projects"
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Yes, I saw the damage. What were the symptoms?
Seems like you just installed it a few months ago.
Wayne,
with all due respect your statement surprises me. Aren't there inherrent problems with every engine Porsche made so far. Look at SCC_ITA's wiring harness off a 993 almost setting the thing on fire, the rear main seal on a 996, the head to cylinder leak on early 964, the valve guides on every pre 993, the head studs, the rod bolts on a 964, non hydraulic chain tensioners, and the list goes on. I think a blanket statement like that doesn't work for me. So far every engine I have come across has one or more of those "known" issues. You just need to understand what you are dealing with and improve on the issues. Ingo
![]() ingo
Now in 993 land ...
Looks like Walt has a real good cleaning machine! That's why I string just about every little bit up on a coat hanger if I have an engine or parts of it "hot tanked".
George |
Team California
Mine looked the same when he was finished w/ them, (except for no 2nd plug holes on mine).
![]() And how many miles are on that motor? My SC had 115k and needed all new lower guides, springs, (one was broken due to defective springs on late SCs), + heads flycut due to minor damage from broken studs on BOTH SIDES of engine. But of course mine was a "bulletproof 3.0", not one of those inferior 3.6s. ![]() ![]()
Denis "It won't interfere with the current building. It'll be near it but not touching it." -Grifter in Chief, July of 2025 |
PRO Motorsports
Can't say that I agree with Wayne. Maybe on the early 3.6's, but from '92-on, they've been bulletproof.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
![]() Those things shore are purdy tho', any consensus on what induces the leak ?? Head/cyl warping or just crappy gasket design... |
Ingo,
If I may ask, what was the bill? I am going to need similar services on another 993 engine soon. Got any contact info? Looks like he did a very sweet job. |
Senior Member
Not to take anything away from Walt (who is one of the best in the business) but a head should come back like that from any competent shop doing a valve job.
Ingo, Very nice!
Every 911 has had its known and infamous weaknesses ![]()
Todd,
I am doing a couple of preventive upgrades such as rod bolts, head studs and head gaskets 'while I am in there". Depending how you look at it its about 3k by the time I am done but I'll have the piece of mind that its done right without cutting any corners. It should give me a relatively bulletprove engine even though Wayne might disagree. Give Walt a call. He also has prices posted on his website http://www.competitioneng.com/Catalog.htm Ingo
Bill,
If you or anyone has a set just taking up precious space in the garage I'd be happy to take them. But I am not willing to sink another 800$ into this project. I also figure changing the cams does not require the heads to come off. So I can always do it later should I get an itch. Ingo
Ingo, Thanks for the info on Mr. Watson. I love new/rebuilt engine parts ![]() |
