-   -   What grease to use on shift bushing? (http://forums.pelicanparts.com/porsche-911-technical-forum/144948-what-grease-use-shift-bushing.html)
amk 01-20-2004 11:43 PM
I was just about to start project 37 (replacing the shift bushings) and realized I've got everything except the lithium grease, doh!
However I do have some bearing grease, Castrol HTB (bentone clay based). Is grease grease? Can I use my bearing grease on the bushings or should I get lithium grease?
Regards,
Andrew.
Zendalar 01-21-2004 12:39 AM
Hmmh, never used lithium grease on anything. Usually i put this Moly...something or just plain vaseline.
amk 01-21-2004 01:26 AM
hmmm... sounds like grease is grease... and in a pinch might even work for a rash ;)
john70t 01-21-2004 05:12 AM
Moly or silicone should be o.k, mabye even lithium, but but the petroleum based products will start to break down rubber.
It should be thick enough to stay but thin enough to self clean and not cause drag.
amk 01-21-2004 01:50 PM
Thanx, I'll get some moly or silicone. What is Moly?
I got a little side tracked last night, once I had the gear shift off I decided that it needed a sand back and re-spray... so now I'm waiting for the second coat to dry.
Phantom911 01-21-2004 07:55 PM
moly = Molybdenum Disulfide(MoS2). It's a lubricant that works under HIGH pressure where most other lubricants would break down.
Randy Webb 01-21-2004 09:35 PM
yes -- it's graphite on steroids (so to speak)
