amk amk is offline
amk's Avatar
Question What grease to use on shift bushing?
I was just about to start project 37 (replacing the shift bushings) and realized I've got everything except the lithium grease, doh!
However I do have some bearing grease, Castrol HTB (bentone clay based). Is grease grease? Can I use my bearing grease on the bushings or should I get lithium grease?
Regards,
Andrew.
1976 911 Carrera 3
Old 01-20-2004, 11:43 PM
Senior Member
Zendalar's Avatar
Hmmh, never used lithium grease on anything. Usually i put this Moly...something or just plain vaseline.
Projects:
911 -72T EFI "964-look" "Smoky"
914 -71 1.7 D-JET "Rusty"
Old 01-21-2004, 12:39 AM
amk amk is offline
amk's Avatar
hmmm... sounds like grease is grease... and in a pinch might even work for a rash
1976 911 Carrera 3
Old 01-21-2004, 01:26 AM
You do not have permissi
john70t's Avatar
Moly or silicone should be o.k, mabye even lithium, but but the petroleum based products will start to break down rubber.
It should be thick enough to stay but thin enough to self clean and not cause drag.
Old 01-21-2004, 05:12 AM
amk amk is offline
amk's Avatar
Thanx, I'll get some moly or silicone. What is Moly?
I got a little side tracked last night, once I had the gear shift off I decided that it needed a sand back and re-spray... so now I'm waiting for the second coat to dry.
1976 911 Carrera 3
Old 01-21-2004, 01:50 PM
Phantom911's Avatar
Send a message via AIM to Phantom911 Send a message via Yahoo to Phantom911
moly = Molybdenum Disulfide(MoS2). It's a lubricant that works under HIGH pressure where most other lubricants would break down.
James Milton
'82 911SC Coupe
'07 GMC Yukon
'92 Jeep Cherokee Sport (rain car)
Old 01-21-2004, 07:55 PM
Randy Webb's Avatar
yes -- it's graphite on steroids (so to speak)
Old 01-21-2004, 09:35 PM
