-   -   CDS Unit Failure (http://forums.pelicanparts.com/porsche-911-technical-forum/145002-cds-unit-failure.html)
RTH 01-21-2004 11:18 AM
CDS Unit Failure
I've got a quick question ? After spending a few days trying to figure out why my 1979 911sc would not start.... I took it to a shop.... they've diagnosed the problem as a failed CDS unit... quoted about $1700 for a replacement....
My question is - when I was looking, the unit put out the "squeal" that signifies operation - can the unit still fail and put out the noise.....?
304065 01-21-2004 11:30 AM
Do a search here, this topic is EXTENSIVELY covered. Search under CDI box (they don't call it BHKZ anymore), a bunch of guys had the same problem.
I don't know the procedure as I have an MSD 6AL which is a heck of a lot cheaper than $1700.
Good luck!
RTH 01-21-2004 11:38 AM
Thanks....I did the search but could not find anything on the noise+failure issue....
Leland Pate 01-21-2004 11:42 AM
I've personally never heard of a CD box dying but still whining.
Sounds like it could be a dead coil?
Always start with the cheapest fix. On top of that, if the box is dead, you can have it rebuilt for about $300. Screw buying a new $1700 Bosch unit. Nobody does that!
Lorenfb 01-21-2004 03:34 PM
Leland is correct. If the CDI buzzes, that indicates that it's probably O.K.
Call Tom at Pelican Parts. He can probably advise you about a Bosch rebuilt,
if you really need another CDI.
Proper diagnostics are always a good idea especially when there're costly
parts involved. The green pickup wire from the dist. may be your problem.
no substitute 01-21-2004 04:05 PM
$1700! So they come in gold with diamond insets. I think $omeone'$ trying to $lide one pa$t you for fun and profit. My Bosch is still going strong and it's in all likelihood the original one, given how long I've owned the car. The Permatune internal coil I bought (so I could go faster) lasted six months. If you truly need one, which seems unlikely, rebuild the Bosch, as suggested. Wiggle some wires first.
Leland Pate 01-21-2004 04:20 PM
$1700 is how much they cost, new. But no one I've ever known has actually SPENT $ 1 7 0 0 on a CD box. You can buy a used one, have your rebuilt, or go with a Permatune or MSD box for a fraction of the price.
http://www.ottosvenice.com/ Is very reputable and can rebuild a CD box.
I'd check the coil and the generator pick-up coax wire (green wire from the dist. to the CD box).
Best of luck,
Jim Richards 01-21-2004 04:49 PM
How's your coil?
RTH 01-21-2004 05:12 PM
They're going to tinker with it for a couple of days to make sure of the problem..... Thanks for all the imput... this is a great forum for those of us who are new the the fast lane........
ejm914 01-21-2004 05:25 PM
I hope your not paying them to learn on your car...
Post your location...there may be someone nearby with a clue
no substitute 01-21-2004 05:34 PM
Ouch, you're right. The '99 Perf. Prod. catalog has them at $1199, expensive even back then. I still don't trust the Permatune, although I understand some folks have run them successfully.
