RTH RTH is offline
CDS Unit Failure
I've got a quick question ? After spending a few days trying to figure out why my 1979 911sc would not start.... I took it to a shop.... they've diagnosed the problem as a failed CDS unit... quoted about $1700 for a replacement....
My question is - when I was looking, the unit put out the "squeal" that signifies operation - can the unit still fail and put out the noise.....?
Old 01-21-2004, 11:18 AM
304065's Avatar
Do a search here, this topic is EXTENSIVELY covered. Search under CDI box (they don't call it BHKZ anymore), a bunch of guys had the same problem.
I don't know the procedure as I have an MSD 6AL which is a heck of a lot cheaper than $1700.
Good luck!
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 01-21-2004, 11:30 AM
RTH RTH is offline
Thanks....I did the search but could not find anything on the noise+failure issue....
Old 01-21-2004, 11:38 AM
Senior Member
Leland Pate's Avatar
I've personally never heard of a CD box dying but still whining.
Sounds like it could be a dead coil?
Always start with the cheapest fix. On top of that, if the box is dead, you can have it rebuilt for about $300. Screw buying a new $1700 Bosch unit. Nobody does that!
Chief Architect and Mastermind,
SCWDP
Old 01-21-2004, 11:42 AM
Lorenfb's Avatar
Leland is correct. If the CDI buzzes, that indicates that it's probably O.K.
Call Tom at Pelican Parts. He can probably advise you about a Bosch rebuilt,
if you really need another CDI.
Proper diagnostics are always a good idea especially when there're costly
parts involved. The green pickup wire from the dist. may be your problem.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 01-21-2004, 03:34 PM
$1700! So they come in gold with diamond insets. I think $omeone'$ trying to $lide one pa$t you for fun and profit. My Bosch is still going strong and it's in all likelihood the original one, given how long I've owned the car. The Permatune internal coil I bought (so I could go faster) lasted six months. If you truly need one, which seems unlikely, rebuild the Bosch, as suggested. Wiggle some wires first.
'80 SC
Old 01-21-2004, 04:05 PM
Senior Member
$1700 is how much they cost, new. But no one I've ever known has actually SPENT $ 1 7 0 0 on a CD box. You can buy a used one, have your rebuilt, or go with a Permatune or MSD box for a fraction of the price.
http://www.ottosvenice.com/ Is very reputable and can rebuild a CD box.
I'd check the coil and the generator pick-up coax wire (green wire from the dist. to the CD box).
Best of luck,
SCWDP
Old 01-21-2004, 04:20 PM
Bandwidth AbUser
Jim Richards's Avatar
How's your coil?
Jim R.
Old 01-21-2004, 04:49 PM
RTH RTH is offline
They're going to tinker with it for a couple of days to make sure of the problem..... Thanks for all the imput... this is a great forum for those of us who are new the the fast lane........
Old 01-21-2004, 05:12 PM
ejm914's Avatar
I hope your not paying them to learn on your car...
Post your location...there may be someone nearby with a clue
Old 01-21-2004, 05:25 PM
Ouch, you're right. The '99 Perf. Prod. catalog has them at $1199, expensive even back then. I still don't trust the Permatune, although I understand some folks have run them successfully.
'80 SC
Old 01-21-2004, 05:34 PM
