twin plugged targa's Avatar
adjusting timing 101 advice please!
Okay guys,
If some one tells you that they set up the timing on your car to " 30 degrees at 3,000 rpm" what do they mean and how did they do it?
They informed me that the only adjustment for timing was by rotating the distributor, so how do you know when 'whatever ' is at 30 degrees.
Can anyone translate this into something this technically challenged man can undertsand.
Ben
AKA "86ragtop" 1986 911 Carrera SOLD 11/2001
1984 Carrera 3.2 IROC RSR look
Old 01-23-2004, 01:22 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
First of all you'll need a timing light. What you do is attach the timing light to the car per it's instructions. Then you aim the light at the crank pulley. at 1K rpms you should notice that a little tick mark shows up near the tick mark on the fan housing. As you rev the engine the tick mark should move (the distributor is advancing) there is a second tick mark at 30 degrees and you should turn your distributor so that @ 3000 rpms that 30 degree tick mark should line up with the fan housing tick mark. Sorry unless you do it it can be hard to explain.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 01-23-2004, 01:28 PM
PRO Motorsports
Tyson Schmidt's Avatar
You use a timing light, and then rev the engine to 3000 rpm. The mark on the bottom of the fan housing should line up with the mark on the front pulley that is 30 degrees in front of the Z1 mark.
But that seems like too much advance for twin-plug. Twin-plug engines don't require as much advance, since it takes half the time to ignite the entire mixture as single plug, necessitating less advance. Usually you can retard the timing from the stock spec by 10 degrees when using twin-plug, but that depends on the specs of the motor.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 01-23-2004, 01:33 PM
That makes sense, although the car is not with me at the moment.
Seems simple?
I will borrow or buy a timing light when next with the car and try it!
Thanks Tim
Rgds Ben
Old 01-23-2004, 01:35 PM
Bill Verburg's Avatar
This may be too obvios(or maybe not). The pulley timing marks mentioned above are only good when the timing light is connected to cyl #1
Bill Verburg
Old 01-23-2004, 01:37 PM
Tyson, the car was a stock 2.7 . But then the garage for the PO had 10:1 cosworth pistons and a custom crane cam. The twin plugs are fired from a 964 twin distributor system, More specs I dont have, which makes life hard when getting/applying advice.
I guess with all of the custom stuff in the engine, I will not get definative answers like timing settings, I guess it is just a case of 'suck it and see!'.
- Bill nothing is to obvious to me!
thanks for chirping in, I appreciate it!
Old 01-23-2004, 01:41 PM
126coupe's Avatar
I always like to put a mark on both the Fan Housing and pully for ease of seeing. I use a sharpie or a permanant marker
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 01-23-2004, 02:03 PM
Hilbilly Deluxe
emcon5's Avatar
Maybe Steve Weiner will chime in, but I believe he said you should set twin plug timing so full advance is 24°.
Tom
82 911SC Coupe
GTI Cup #43
Old 01-23-2004, 02:45 PM
oops, sorry Wayne
guess I have not got to that section in the book yet, figured that maybe this engine was that different that maybe it was'nt the same as regular engines.
Old 01-23-2004, 03:59 PM
PRO Motorsports
Tom
Yep, sounds right to me.
2004 GT3
Old 01-23-2004, 04:10 PM
anh911's Avatar
when you're doing this for the first time it helps to have a helper sitting in the left seat and doing the RPM thing. Standing a foot from the fan with a timing light in one hand and revving the motor to 3K can be daunting to the uninitiated. Also get a good 13mm crowsfoot or dist wrench. Don't stick your paws in there with a regular wrench wilst the motor is running.
Oh yeah, don't do this while wearing a tie!!!
anh911
'94 Dakota - Meh
'98 Moto Guzzi - woo hoo
911; XJS; Islander 36; All Sold
'97 YZF1000RJ - Totaled (Not by me)
Old 01-23-2004, 05:04 PM
