kim914's Avatar
83' 911SC overheat problem..
I have a 83' 911SC, no modify at all. It had upgrade oil cooler already, everything stock, when I drove back home two days ago, it was pretty traffic and my car start overheating, is there any oil pump problem or motor oil grade make some different? What should I check frist?
Thanks for your help.
Kim
Old 01-23-2004, 12:16 PM
vash's Avatar
is your fan working? and superman just told me that his SC had a bunch of crap/sludge in his oil cooler. things went better when he had the system cleaned out. also, make sure your fan belt is tighten correctly. just what high temp were you seeing?
poof! gone
Old 01-23-2004, 12:20 PM
Kevin Stewart's Avatar
I would check the thermostat behind the right rear wheel, let the car warm up, then put your hands on the tubes after it that go to the oil cooler and see if they are hot, Kevin
Old 01-23-2004, 12:36 PM
Often its the guage/sender that becomes inaccurate. You want to check its something simple like this.
Old 01-23-2004, 01:06 PM
kim914's Avatar
I'll check the thermostat and oil cooler to see what happen. Also I notice that the oil level guage jump up and down when my car at idle.
Kim
Old 01-23-2004, 05:15 PM
kim914's Avatar
O.K. I did the oil change, and start the car, warm that up to 3/4 of the tempeture guage. And I touch the oil line to the front oil cooler, Still cold. When will the thermstat open?
Kim
Old 01-26-2004, 02:45 PM
disband
juanbenae's Avatar
long before the gauge hits the 3/4 point. you do mean 3/4 up, right?
Old 01-26-2004, 02:51 PM
GrindingGears's Avatar
Mine stays cold until a few minutes after the oil temp has reached the first tick. Drive it spiritedly for 10 minutes after it has reached that first tick, that's when mine gets hot.
83 SC (gone) // 72 T (gone)
Old 01-26-2004, 02:56 PM
Sounds like the thermostat is allowing oil to move up to the front cooler. I would guess that either the thermostat is bad or that one of the lines running under the rocker panel got pinched (tire change is typical culprit).
1999 996 C4 Cabriolet
1997 BMW M3 (Hail)
1985 928 S (Sold)
1982 SC Targa (Sold)
Old 01-26-2004, 03:02 PM
kim914's Avatar
Now the temperture guage on 1/2, and I feel the oil thought the front oil cooler now, is that too high for the thermostat open? Or is normal?
Thanks for all of you guys.
Kim
Old 01-27-2004, 08:57 AM
Oil should start flowing to the front when the engine gets to about 190 degF..the second white line from the bottom at 8 o'clock position. Function of the thermostat in the right-rear fender well.
--Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 01-27-2004, 04:40 PM
UTKarmann_Ghia's Avatar
Send a message via Yahoo to UTKarmann_Ghia
The tstat on my SC opens at around 200 degrees. That's just above the second white bar on your temperature gauge.
There are many reasons your car may overheat. If you do a search on my user name in this forum, you will find a few threads that detail many different things to check and how to check them. There's alot of experience in there that could help you.
Matt
'82 911SC Targa!
Old 01-27-2004, 05:27 PM
