Settings for Electromotive HPX ignition
Hi,
I have the electromotive HPX ignition in my car. Here is a link to the product The motor is a 1982 911SC motor with 9.3 to 1 compression (I believe) and PMO carbs. P&Cs are stock so I'm using CIS pistons. Also using stock cams. I was given this information to use as the initial settings. initial advance: 10 degrees advance added at 3000: 32 degrees (+/- 1 degree) advance added at 8000: 2 - 4 rpm limit: factory spec for '82 SC (what is redline? to be safe I set it at 5900rpms) I am using Bosch W5D plugs gapped at a 27,000th. What settings are other folks using on their single plug HPX ignitions? Am I using the right plugs? How about the plug gap? Electromotive has the user manual online, but I don't quite understand the part about ignition advance. Link to user's manual Thanks. Chuck
1981 Porsche 931 w/S1 engine & g31 transmission. Water-cooled intercooler Last edited by chuckw951; 01-15-2004 at 08:56 AM.. |
Super Moderator
Chuck,
Those settings sound about right. I used a few degrees less than that, but I am running twin plug. My settings are at: Initial = 8 deg 3000 = 29 total (+21) 8000 = 26 total (-3) You can set your rev limit higher though. 6200-6500 would be plenty safe. I'm using the standard plug-gap, I think at .035? Not sure about the plugs though, I'm using NGK. I would stick with a stock heat range. What are you having trouble with regarding the advance?
Chris,
Thanks for the info. Quote:
1981 Porsche 931 w/S1 engine & g31 transmission. Water-cooled intercooler |
Super Moderator
Well I know plenty of guys that run up to 35 degrees of advance at 6000 RPM... But you have to watch for pinging. You can probably advance a little more without worrying.
How you you guys with HPX feel about replacing Magnecors every year
![]() I'd hope tough wires would be good for 5 years with the HPX, did the manufacturer say different or just not want to talk about it ? |
Super Moderator
I've never heard of replacing them every year... where did you see this?
Gawd I hope not considering what a set of 12 pre-cut costs!
I run similar setup with W6D on track and W7D for street - both gapped at .032
Mike - PBG, FL '14 958 Cayenne GTS '05 997 C2 - SOLD '79 911 SC Widebody PCA, NASA, PBOC - SOLD 2004 NASA-SE GTS4 Champ, 2005 + 2007 NASA-SE GTS3 |
Exactly the kind of thing I would blow off until I saw empirical evidence of a FUBAR problem. need any more acronym zombie madness ? woof. |
"1. DANGER! The HPX generates high voltage that can be lethal. Do not ever touch a coil tower or spark plug wire when there is a chance of a spark. 2. Without the spark plug wires on the coils and spark plugs, the system will generate dangerous levels of voltage that can damage the HPX. This can also lead to fatal electrocution. 3. Do not let the spark plug wires touch the block, head, frame or body. The power of this ignition can burn through most spark plug wire insulation. Use a quality 8mm (or larger) wire with two piece spring loaded contacts and wire separators. Replace spark plugs wires every year (recommended)." Any product that could cause "fatal electrocution" has to be cool. I think these warnings were recommended by the lawyers. I'm not going to replace my wires every year. I'll take the risk.
Super Moderator
CHuck,
Initial Advance at +10 degrees 3000 RPM Adv at +25 8000 RPM Adv at -4 THe effects of each advance dial are additive.
I drove around for a hour or so and the seat of the pants meter tells me that the car has more top end power, but less mid-range pull. Does that make sense? Chuck
Super Moderator
Chuck,
12 is really too high for intial advance and would result in harder starting. In fact the Electromotive and others have the ability to temporarily advance or retard the timing curve. Often high compression race cars will dial timing back to ZERO(!) to make them startable. If you are flatter on the mid-range, you might try dialing a little advance out. In general advanced=horespower, retarded=torque. The electromotive curve in the mid-range is MUCH more advanced than stock. Here is a graph that I used to define it when I dial in my curves for particular tracks... The green and red are the top and bottom ranges for the factory advance curves on an early SC motor. The blue represents the initial advance curve from electromotive... I've found that while this setting works well in my race car with a close ratio gear box it doesn't work as well on a street car. I think the higher advance at 3000RPM "steals" torque but gives a better HP curve. THis isn't necessarily proven or even scientifically accurate, but only based on my subjective experience at the track. So try something like: Intial +10 3000 RPM +(10-12) 8000 RPM +(8-10) And I bet that will get rid of your flat spot. chris
Once you get above about 40KV on the coil output, it's of little value and
just stresses the whole ignition system. The same goes for the spark energy. Anything over 60 to 100 millijoules is of little value. Check out this web site (www.systemsc.com) on the Technical page in the Ignition Systems section.
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone |
Super Moderator
Loren,
I'm not sure how this ties in, can you elaborate?
Chuckw951 raised the issue of the HPX high voltage. My response
assumed that it was one of those aftermarket units where extra high energy and voltage is part of the marketing claims. Sorry, to divert from the key focus which is timing. Also, this is a great thread from the standpoint of setting the proper advance curve. This is in contrast to what we've seen on the 3.2 discussion threads, i.e. a little more intelligence and reality.
Super Moderator
Thanks Loren, I forgot about the "voltage and wire replacement" bit earlier in the thread!
![]() CHeers. Chuck, Please post back if you have positive results!
![]() Tempting, tho'... matching up the ignition w/ the EFI conversion makes me think about not re-installing my CIS. |
