New Axles - Gasket Question
It's been a while but I've started working on the 911 again. Started with the replacement of 1/2 shafts. The installation went well and I took my time to clean, inspect and re-install. As of last night, the axles are in, torqued and clean!
One thing I forgot as I re-ran the install through my mind. When I placed the gasket on the each of the ends, I forgot to remove the thin paper that exposes the sticky side. Will this be a problem? I know for a fact they all lined up well because I took extra care to make sure all was OK before I torqued (to 60 ft-lbs) all the bolts. I really don't want to remove and reinstall. Please let me know what you think. |
Ahh...60 ft/lbs?
Make sure you have the 85+ version of the 911 half shafts.. or the 930 version that uses 10mm bolts...these are the only ones torqued to 60 ft-lbs. The smaller ( 6-8mm) are like 34 ft-lbs. Check the size. ---Wil Ferch |
Shouldn't be a problem. I think the sticky stuff is just there to help keep it in place while you're doing the install. I forgot one gasket all-to-gether and it's never spit grease out. But, I was still disapointed when I got done and I had a gasket left!
As Wil says, if you are using the M8x50 you have overtorqued your bolts.
I didn't even know you could peel the paper off when I regreased mine. I figured it out and went back in to stick them -- they didn't! Question for the group: How often does the circlip holding the CV need to be replaced? After each removal? After many, many years of use? After <n> number of times? Many thanks, John |
Thanks for the replies. I'll drive it around and see what happens.
As for the size of the bolts, they are the 10 mm bolts, four per side. I even found a place locally that carries Schnorr washers. |
I also left the backing on a gasket of mine. Didn't realize until I did the other side.
I have had no leaks and will replace it in the spring when I do a clutch job. |
Thanks tt targa!!! That is very encouraging.
| All times are GMT -8. The time now is 06:20 PM. |
