Dash clock repair
Well I was so proud that my clock still worked after 20 years. Clock has stopped. Has anyone ever tried to service their quartz VDO dask clock? Any documentation out there?
I had the car on a slow charger so the battery would stay pumped up. I have wondered if the dirty power might have killed the clock? The car is an 83 911. The clock says Quartz. Don't know when they changed over from mechanical. I can't seem to get it open to even diagnose whether it is a mechanical or electrical failure. Looks like bezel is pressed or bonded in somehow. A new replacement is $185 from PP. I'm sure all used are suspect. Any comments? |
Re: Dash clock repair
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please ![]() Chad aka "Chili" 1974 Base coupe in Carrera outfit. No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.) My car http://www.pelicanparts.com/gallery/CHILI 1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras. |
These guys have been mentioned on the board before. I have no experience with them, give 'em a call?
http://www.paspeedo.com/index.htm
83 SC (gone) // 72 T (gone) |
Well...I'm a big supporter of this board, so this is always a bit of a sticky subject. I always try to buy parts from Pelican. Yet, my VDO clock had a cracked front lens when the P-Car arrived on my door step. So I replaced it with a used one from a Porsche dismantler. This replacement clock works perfectly to this day. While you take your chances, it seemed to work for me...cost me $65.00.
Jason 88 911 Cab Last edited by cicsprog; 01-27-2004 at 04:23 PM.. |
easy to repair !
check the tech articles on this board Philippe |
Its probably just dirty and in need of a cleaning. I took the two rear screws out, sprayed in electronic cleaner (electrical cleaner will also work ) , left it dry and reattached it. Works fine. Try it before disassembling.
