yama1's Avatar
Question How Fix O2 sensor main wire in body
On my 85 3.2, I noticed that the black wire leading to the o2 sensor was hanging and appeared to have been this way for awhile. The main green wire that mounts to a bracket with the rubber coated plastic insulator was broken. The plastic just came apart and I pulled the green line through it. How do I go about replacing or fixing this insulator between the main green wire and the black sensor wire. The main line seems to be very rigid and does not appear to be a normal shielded wire. Is there a way to splice in a new insulator or do I even need this. Would it be possible to splice together without the insulator.
I will update with pics soon!
thanks for any info.
85 Euro 911 carrera
77 911 widebody coupe
"Drive the Ride"
Old 02-01-2004, 02:22 PM
