Crane Cams - anyone used them?
Has anyone used crane cams in their cars?
My 2.7 has a crane cam I am told. I have visited the web site and they only show 3 possible cams for 2 litre 3 litre and 3.2 litre. I am guessing mine is this one as the performance takes off after 4K revs. Any other way of knowing from the outside? here are the specs: Part Number: 520-0012 Grind Number: P-306 Engine Identification: Start Yr. End Yr. Make Cyl Description 1965 Up PORSCHE 6 Fair idle, moderate performance usage, good mid-range horsepower. Basic RPM 4000-6800 Engine Size Configuration 1991 C.C. Valve Setting: Intake 0.1 MM Exhaust 0.1 MM COLD Lift: Intake @Cam 8.49 MM @Valve 12.55MM All Lifts are based on zero lash and theoretical rocker arm ratios. Exhaust @ Cam 7.96 MM @Valve 11.73MM Rocker Arm Ratio I-1.477/E-1.475 Cam Timing: VALVE @.305 MM Lift: Opens Closes ADV Duration Intake 51 BTDC 75 ABDC 306 ° Exhaust 66 BBDC 42 ATDC 288 ° Spring Requirements: Triple Dual Outer Inner Part Number -- Loads Closed -- LBS @ -- or -- Open -- LBS @ -- Recommended RPM range with matching components Minimum RPM 4000 Maximum RPM 6800 Valve Float -- Cam Timing: VALVE @1.0 MM Lift: Opens Closes Max Lift Duration Intake 34 BTDC 58 ABDC 102 272 ° Exhaust 49 BBDC 25 ATDC 102 254 ° Whatever all that means rgds ben
AKA "86ragtop" 1986 911 Carrera SOLD 11/2001 1984 Carrera 3.2 IROC RSR look |
Hmmm.. guess noone uses Crane Cams
Ok, anyone know if there is anyway that I can tell from the outside , which cams I have?. please excuse if this is a daft question. Also I can tell a huge change in engine tone at 4K+ revs, which I was sure was detonation. A friend told me that a rough Porsche engine that sounded like a can of dried peas in a can at idle was that way due to race cams. Do race cams make the engine sound rattly at idle or is it possible that the cams I have are making rattle noises at higher revs? Again sorry if this question is daft, I am just fishing for hopeful easy answers which are not going to cost $$$$$$ in rebuilds Rgds Ben
I have the exact same P-306 cams in my racecar. Good balance of power and torque. I do not rev my race car over 7300k (well sometimes
) so this was the perfect choice for my race motor. The only way to check it is to yank the cams out.
Chad Plavan 911ST Race Car/2.5L SS Race Motor #02 1972 911T- Numbers matching- Restoring to stock 2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold) 2016 Elan NP01 Prototype racecar- Chassis #20, #02 Last edited by Plavan; 02-01-2004 at 10:33 AM.. |
Hilbilly Deluxe
You can degree them, but not with the engine in the car.
Details here: Webcam, real or fake Ben, you really need to do some detective work, and find out who built the engine, and what he put in it. Looking at jluetjen's chart, that is a pretty hot cam, higher lift/duration than a 906. ![]() Tom |
GAFB
I have Crane P-288s in my 2.4 sleeper motor. One of 'em, can't remember which, has a stamping in the end of the cam for ID purposes. Pull your chain covers and see if yours do, too.
After spending a lot of time with modified Porsche engines, I can't say I've ever heard a healthy one sound the way you describe. Before worrying about $$$ for rebuilds, I'd go over the basics and gather some facts. Check valve adjustment, look for exhaust leaks, broken head studs, etc.
Several BMWs |
