-   -   Turn Signal Problem (http://forums.pelicanparts.com/porsche-911-technical-forum/146591-turn-signal-problem.html)
mm86911 01-31-2004 07:48 PM
Turn Signal Problem
Just started to diagnose this problem but know that the flasher is good (new) and all wiring appears in order. The low beams work but highs only when you flash at the stalk (high position on stalk gives no change). All other exterior lamps work and when you pull turn signal to either side with keys out low beam and mark lamps illuminate properly. Is this as simple as a new multi-funtion switch?
vash 01-31-2004 10:19 PM
is the stalk switch still good? those things burn easy.
djmcmath 01-31-2004 11:03 PM
I'd guess the switch, having just taken apart the whole headlight electrical system. That thing's a real pain to get to though, and it runs about $100 to replace, if I remember right. Can you jiggle it in the high position to make them work?
Dan
ruf-porsche 02-01-2004 02:36 AM
Replace the switch.
mm86911 02-01-2004 07:34 AM
Thanks - switch will be next approach as I suspected.
