mm86911's Avatar
Turn Signal Problem
Just started to diagnose this problem but know that the flasher is good (new) and all wiring appears in order. The low beams work but highs only when you flash at the stalk (high position on stalk gives no change). All other exterior lamps work and when you pull turn signal to either side with keys out low beam and mark lamps illuminate properly. Is this as simple as a new multi-funtion switch?
Mike - PBG, FL
'14 958 Cayenne GTS
'05 997 C2 - SOLD
'79 911 SC Widebody PCA, NASA, PBOC - SOLD
2004 NASA-SE GTS4 Champ, 2005 + 2007 NASA-SE GTS3
Old 01-31-2004, 07:48 PM
vash's Avatar
is the stalk switch still good? those things burn easy.
poof! gone
Old 01-31-2004, 10:19 PM
djmcmath's Avatar
I'd guess the switch, having just taken apart the whole headlight electrical system. That thing's a real pain to get to though, and it runs about $100 to replace, if I remember right. Can you jiggle it in the high position to make them work?
Dan
'86 911 (RIP March '05)
'17 Subaru CrossTrek
'99 911 (Adopt an unloved 996 from your local shelter today!)
Old 01-31-2004, 11:03 PM
ruf-porsche's Avatar
Replace the switch.
Old 02-01-2004, 02:36 AM
mm86911's Avatar
Thanks - switch will be next approach as I suspected.
Mike - PBG, FL
'14 958 Cayenne GTS
'05 997 C2 - SOLD
Old 02-01-2004, 07:34 AM
