RSR.guy's Avatar
930 Rotor / Caliper Question
Guys,
I am considering fitting a set of 930 (turbo) calipers to an early car. Do 930 rotors also need to be fitted? Are there alternatives to the ultra-expensive and crack prone monsters?
Thanks in advance.
Cheers, Chris
Old 02-05-2004, 08:54 AM
Somewhere in the Midwest
MotoSook's Avatar
"early car" ..what year?
There was a good thread this week about 951 brakes on a 911. In it you can also learn about 930 brakes. Search "944T on 911" and it should come up.
Old 02-05-2004, 09:08 AM
If you simply do a search on brake guru "Bill Verburg"...you'll be miles ahead.
--Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 02-05-2004, 09:16 AM
beepbeep's Avatar
Well they aren't sooo ultra expensive (especially if you can fit non-floating ones, cost around 100 bucks a piece) or more crack-prone than any other cross-drilled rotors.
Thank you for your time,
Old 02-05-2004, 09:23 AM
RSR.guy's Avatar
Thanks guys. By early, I mean ' 73. I'll do a little searching.
Cheers, Chris
Old 02-05-2004, 10:49 AM
don911's Avatar
Chris,
If you need the calipers, I know where a set is for sale in the Seattle area. (at least they were for still for sale last I knew). Send me an e-mail if you're looking for calipers.
As far as rotors... The factory rear rotors worked on my 87. Don't know about an early car. The factory rears are not expensive and I don't think they are as crack prone as drilled rotors.
If you have flared front fenders, I think you can use the post 1980 one piece front rotors which are not as expensive.
I have an old set of rotors off an 89 930 if you need to do any fit checks.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 02-05-2004, 11:29 AM
Bill Verburg's Avatar
Yes, any '78-89 rear will be fine but the fronts need to be '78-'80 2 piece only or aftermarket equivalents w/ zero o/s hats.
Yes and no, you can have one of the 2 criteria but not both, there are also compromise solutions. With a lite car cracking is a less compelling issue so you can get by w/ cheaper rotors.
Bill Verburg
Old 02-05-2004, 01:28 PM
