-   -   having problem taking cat off (http://forums.pelicanparts.com/porsche-911-technical-forum/147372-having-problem-taking-cat-off.html)
krichard 02-05-2004 09:45 PM
I have grinded off all the bolts holding the cat on and now I'm trying to sperate it from the heat exchangers. I can't get it to budge. Anyone have a suggestion?
v9ff 02-05-2004 10:16 PM
You could try heating up that area where they connect... that should make them more receptive to a "prying" separation, no?
krichard 02-05-2004 10:20 PM
I don't have a Oxy/Mapp or acetylene setup just a propane torch and I don't think it will get it hot enough. I tried it for a while with no luck.
tab tanner 02-05-2004 10:30 PM
Soak it with P.B.blaster, This stuff is the best thing I have ever seen.Autozone sells it as well as other stores. I'm shure this will help you good luck
v9ff 02-05-2004 10:43 PM
You say you've grinded off all the bolts... does that mean you just cut off the head and the end bolts? If the main part of the bolt is still in the hole then it might be the culprit. Perhaps you can try cutting the shaft of the bolts off inbetween the cat and heat exchanger.
Eric Coffey 02-05-2004 11:56 PM
big rubber mallet?
cyprusx 02-06-2004 05:16 AM
Take a punch and a hammer and punch those rusted bolts out.... I just did this and you have to get the bolts out before it will seperate...
