Robert Sanchez's Avatar
Question unstable low RPMīs
I have a 1984 3.2 that seems to take longer now to stablize after a cold start. Before it us to go up and down about 3 or 4 times, now it takes a few minutes untill til the RPMīs become stalbe. What part should I check first?
Bob
930 black cabriolet euro 89
Old 02-03-2004, 10:14 AM
Clean(very well)the valve idle with carburettor cleaneer and control your c.o. nivel.
good luck.
Old 02-03-2004, 11:04 AM
Have you updated your head temperature sensor with the two wire sensor?
Cheers,
Joe
Old 02-03-2004, 12:52 PM
yes, did that acouple of years ago. This is something that has just started yesturday.
Old 02-03-2004, 01:43 PM
RETIRED
Joe Bob's Avatar
Sounds to me like it's sucking air some place....have you LIGHTLY sprayed ether or carb cleaner around the gasket areas of the intake?
Does the idle steady out when warm? Does steady out quicker when the outside temp is higher?
2012 ML350 3.0 Turbo Diesel
Old 02-03-2004, 02:33 PM
I am having the exact same problem on my 88 3.2. I am interested in what you find that fixes it.
Kerry
'91 C2T
'88 Targa - gone
http://www.pelicanparts.com/gallery/krichard/
Old 02-03-2004, 02:45 PM
Mike once it heats up it runs fine. Its the five minute it take to reach the ideal temp that is buging me. The idle will run up and down between 500 and 1500 rpms.
Bob
Old 02-03-2004, 03:47 PM
Send a message via ICQ to Kurt B Send a message via Yahoo to Kurt B
This may sound a little off the wall, but I chased unstable idle on my 3.2 for a long time and actually noticed the biggest change after I changed my alternator. It's very steady now. Whether the voltage just messes with the DME electronics or if the bad bearings actually cause the problems, I can't say, but the idle completely cleared up.
It is likely there are several things going on. I too changed the cold start valve (or the valve on the front of the manifold, cylinder), plugs, injectors, over the years, and nothing really helped until this last bit).
Check the small vaccuum lines as well, esp near the oil filler side of the car and behind the manifold.
-kb-
Old 02-03-2004, 04:00 PM
Thanks Kurt, looks like I am in for some fun!!!!!!!!!!!!!!!!
Old 02-03-2004, 04:08 PM
Try lowering your base idle speed and see if that helps. It may be that simple. And if that doesn't help, you can always raise it back up.
Joe
Old 02-03-2004, 05:27 PM
3.2 CAB's Avatar
After I replaced Ref/Speed sensors my engine has quit the idle hunting and the high idle 1500-2000 rpm that it used to do for no apparent reason at various times.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 02-04-2004, 02:49 AM
Is the Ref/Speed sensors the same as the idle speed regulator?
Old 02-05-2004, 08:38 AM
Krichard, last night I cleaned the idle valve with some carb cleaner and today the car is running a lot better and the idle is stable so far.
Thank to Diana for that tip.
Old 02-06-2004, 01:56 PM
Thanks for the tip. I will try that this weekend.
Kerry
'91 C2T
'88 Targa - gone
Old 02-06-2004, 02:05 PM
