Stupid Question about wheels
I have a set of old wheels. No tires on them. How can I determine their size?
Are they Porsche wheels? Steel or alloy? Fuchs? Brand?
The diameter and width are easy enough to determine. The offset a bit trickier. Also, the size may be stamped on the inside of the wheel. This thread should help you out: offset on BBS rims
Warren & Ron, may you rest in Peace. |
Schleprock
Look on the backside of the wheels, inside the spokes. On an original Porsche wheel, there should be some stampings or castings that resemble something like this:
The above picture is what you'd find on the back of a 16 in. diameter, 6 in. wide Fuchs wheel like this:
Kevin L '86 Carrera "Larry" |
Does the 6 on the silver pic tell you it is six inches wide?
What does the J mean? Also...if the wheels are aftermarket and there are no stamps...can you simply measure? Sorry for the ignorance. . . I've just never known how to figure this out. Thanks for the reply! |
Schleprock
Yes. The 6 means it's 6 inches wide (but not really).
The diameter of the wheel is measured like shown in this picture from Bill Verburg: The J means the wheel is constructed with a safety bead. No need to apologize. Asking lets others learn the same stuff. Do a search with the search button up at the top right of the page and see what else you can find? Like this topic: Wheel Info Topic
Did you read the link I listed?
I have now. For some reason I missed it. Probably all the pretty pics by KTL.
THANKS TO BOTH OF YOU! |
