Poll: Which tranny oil
Poll Options
Which tranny oil
stefang's Avatar
G50 gear oil
I searched, but most of the discussions seem to center around 915 boxes. The 944 seems to like Redline 75w90 gear oil, but I saw a few mentions for Mobil 1 for the G50. So what do you guys use? One work better than the other? Anything else?
Stef
Old 02-12-2004, 10:49 AM
white87911's Avatar
redline
When I bought my car it had Mobil 1 in the G50, did not like the way it performed, seemed a little clunky. Switched to Redline 75-90 and shifts smoother. I have used Redline gear oils in 3, now 4 different manual trans. and had good luck with all of them.
Check to make sure you get the right GL# as all gear oils are not the same. For more info on that cheeck out the redline website.
Old 02-12-2004, 11:02 AM
I have an 87 w/ g-50 and recommecnd the Red Line also but there is a differance. get the 75/90 ns instead of the regular 75/90.
Keith Epperly 87 turbo look slant nose carrera cabriolet
Old 02-12-2004, 11:48 AM
KTL KTL is online now
Schleprock
KTL's Avatar
I've used Swepco and Mobil 1 so far. Mobil is far better and less noisy.
Next change I plan to try Redline. Had good results with that stuff in my Laser. A guy from Redline recommended a blend of different Redline gear oils for my G50 911 and the Laser.
For the G50 I believe he recommended 1 qt. Lightweight Gear Oil (which is a 75W/80W GL-5) and the remainder 75W/90NS (has no friction modifier/additive), regardless of whether you have a LSD or not. He claimed that the Porsche ZF clutch pack-type limited slip differentials don't suffer from chatter like other LSD's do. The NS fluid also is claimed to allow faster synchronization. I believe the Lightweight Gear Oil recommendation is to help cold shifting?
http://www.redlineoil.com/frames/gearoil.htm
http://www.redlineoil.com/redlineoil/gearolti.htm
Kevin L
'86 Carrera "Larry"
Old 02-12-2004, 12:09 PM
Just be careful as most Redline products are GL-4 rated...you need GL-5.
Some Redline products are GL-5.
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 02-12-2004, 01:16 PM
stefang's Avatar
---Wil Ferch
Thanks for the reminder, but I got that. Basically their manual transmission products are GL4 and the gear oil products (for transaxles) are GL5.
Stef
Old 02-12-2004, 03:52 PM
993.986.'s Avatar
According to the service manual that came with my 87 Targa it should be 75-90W GL-5.
Lester
87 Carrera Targa
03 S430 4-Matic
07 Escalade
96 993 Coupe - sold
Old 02-12-2004, 07:49 PM
