Dumb . . . Really dumb question
I'm just about finished with the tranny and started to put the end cap on when I realized I didn't take a picture of where the ground strap goes . . . . . I know its on the passenger side, but which stud does it go on????
![]() Help would be much appreciated at this point since I am almost finished. TIA
'94 CMC Firebird Trans Am '86 951 LS1 (C-2) Gone ![]() ![]() '77 911 3.2 (C-1) Gone but not forgotten. http://www.pelicanparts.com/MotorCity/marcesq1 http://www.youtube.com/user/958Fan#p/u |
Is this right??
Can't quite remember, but it's either that one or the next one clockwise (as depicted). It doesn't really matter since either should be close enough for the strap to attach at the other end.
Eugene (Formerly) at Pelican Parts Pelican's E-Commerce Guy, 2003-2011 2001 330i Sport 1983 911SC Coupe (sold) |
Montana 911
look ok to me...can't recall which mine is on.
H.D. Smith 2009 997.2 S 3.8 PDK 2019 Ford Ranger Lariat FX4 Baby Raptor 2019 Can Am Renegade 1000R XC 2020 Yamaha YFZ450R |
Thanks guys . . . she's all sealed up and filled with fresh tranny fluid.
an extra long ground strap to the starter bolt won't hurt..
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
how dumb does that make me if I can't answer a really, really dumb question? ok-don't answer...
1980 911SC Targa 3.6L |
You have it on the correct bolt per the factory shop manual. Jim
i alway heard it was wise to change that strap to a new one whenever possible. what do you think? when i am there i am also going to add and extra one.
cliff
poof! gone |
I like electrical overkill, and back ups. I also use Neverseize Loctite Graphite-50 for spark plugs. If you read the copper can you can't find spark plugs for suggested use.. you can find that on the Graphite-50 can info.. computer gizmo wiring is another story.
