v9ff's Avatar
Question Fiberglass body panels: Why white or black?
I've seen them raw from the manufacturers in white or black resin(sp?) I think.
Why are some white or black before painting?
Can you request that they be black or white or is it just part of the process of manufacturing?
For street use, can you use them without painting them or will they be unprotected?
Old 02-15-2004, 09:02 AM
RETIRED
Joe Bob's Avatar
It's a choice of manufacturer's....fortunately my car is white and happens to match the white gelcoat. When I break down and paint the car...I will do the f/g pieces as well.....
2012 ML350 3.0 Turbo Diesel
Old 02-15-2004, 09:18 AM
v9ff's Avatar
How long can you run gelcoated fiberglass panels? Will they wear down faster without the paint protection?
Old 02-15-2004, 09:28 AM
RETIRED
Joe Bob's Avatar
Mine have been on over a year....no wear. Except for rock chips.
Old 02-15-2004, 09:49 AM
Apart from the gelcoat not being impervious to moisture and not UV stable, there's really no reason you can't run it raw for a while. The color is completely the whim of the fabricator.
Old 02-15-2004, 10:42 AM
I think a lot of f/g body panel manufactures use white gel-coat because black will amplify all the imperfections waves in larger panels..
Chris
Old 02-15-2004, 12:26 PM
rfuerst911sc's Avatar
Fiberglass boats are generally white gelcoat and last for a long time with frequent washing and waxing and they don't have a paint topcoat.
Old 02-15-2004, 12:36 PM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
Marine gel coat ( aircraft also) have a uv protection additive in them. It increases the cost of the gel coat, most automotive f'glass parts are painted shortly after installation which is why manufacturers don't opt for the more expensive material.
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 02-15-2004, 12:48 PM
v9ff's Avatar
Sounds like the waxing part helps keep gelcoated fiberglass in shape... that may be a better alternative than a multi thousand dollar paint job.
Old 02-15-2004, 12:49 PM
Zeke's Avatar
Many molds are black (tooling gel) and the white gel is easier to spray on a contrasting surface. My favorite gel is primer gel which is gray. It is pretty much the same as polyester primer/surfacer. Hardly anyone uses it. I was in the FG business for a few years a long time ago. I never made any black parts 'cause all my molds were black. Red tooling gel lets you do both.
Old 02-15-2004, 04:24 PM
Otto's Avatar
We can order them in either black or white and also I have had them gel coat to color. Otto
Racing Porsche for over 30 years.
http://www.OttosVenice.com
Check out the Porsche Owners Club Track event Videos
Old 02-16-2004, 10:43 AM
