Ride Height
In an 88 coupe that is predominately (not soley) used on the track, what are you using for a front and rear ride height. Did you need a bump steer kit with your height adjustment? Thanks for whatever insight you can provide.
Old 02-16-2004, 01:37 PM
white87911's Avatar
scooter, just go to the bottom of the main technical forum page and search ride height. You will find a tons of info. My 87 is 25.5" front 24.5 rear. with bump steer kit.
"Coffee is for Closers"
"Push the button Max!!!"
Old 02-16-2004, 02:12 PM
Thanks so much!!!
Old 02-16-2004, 03:49 PM
John M
jmarenas's Avatar
Ride Height
23.5 Back, 24.5 front 17" wheels 255 40 back 205 50 front tires
"I Can't Drive 55!!
Old 02-16-2004, 05:01 PM
Ride Height
I did a search on the many ride height postings but still have one question. Measuring from highest part of the fender arch my car is currently at 24 1/4 F and 24 1/4 R. Using the rule of Front being 1/2 to 3/4 higher than the Rear I should raise my Front to 24 3/4 to 25 (of course many of you have 1" difference F to R).
BUT, is this rule true for widebody cars? Can anyone confirm this? Don't know if the widebody and the narrow body cars have the same fender arc.
I put in HD front/Sport rear Bilsteins, lowered and corner balanced the car. Handles like a dream, but the front really takes a pounding when I hit any bump in the road. Moving the front up a bit can only help.
Thanks Brad
Old 02-20-2004, 08:44 AM
JMARENAS:
what offset have your wheels 17´´?
Regards
Luis
Old 02-20-2004, 09:17 AM
