-   -   SC Rebuild - current status (http://forums.pelicanparts.com/porsche-911-technical-forum/149718-sc-rebuild-current-status.html)
danielt 02-20-2004 01:35 PM
Thought I would post some pics of the current rebuild. Another testimony to the outstanding book written by Wayne on the rebuild.
http://home.comcast.net/~tisserand/engine_plan.html
I will also be documenting the install of an SDS EM-4F EFI system, so if interested, stay tuned!!!!
Thanks,
DAniel
vash 02-20-2004 01:37 PM
yowZA!
Tim Walsh 02-20-2004 01:38 PM
Very cool
danielt 02-20-2004 01:46 PM
Would this qualify for a free SCWDP t-shirt for advancing the cause????
danielt 02-20-2004 02:54 PM
If you're interested in the SDS install, I now have an update on what is modified on the wiring harness. If you see something glaringly missing in the steps, don't hesitate to point it out. I have already screwed it up once by cutting off the wires to the oil pressure and temp sensor. Live and learn...
Daniel
carmaneddy 02-20-2004 03:05 PM
Very Nice job, what was the displacement of the engine when you started? Please post some pics of your car.
mjshira 02-20-2004 03:12 PM
looks great
MY83SC 02-20-2004 03:21 PM
What pistons and cans did you use? I am looking at twin plugs with 10.3
danielt 02-20-2004 03:51 PM
Carmaneddy,
It is a 1981 911SC:
http://home.comcast.net/~tisserand/i...firstrally.jpg
I started rebuilding the 3.0L due to three broken head studs...
Mike,
The Pistons at 98mm JE with 9.5-1 comp. Cylinders are bored and replated 95mm cylinders. All from EBS Racing. The pistons are available in just about any comp you want. I think 9.5 and 10.3 are off the shelf parts and are immediately available.
Daniel
88 Club Sport 02-20-2004 05:51 PM
I'm impressed. What are you HP are you anticipating out of this motor?
danielt 02-20-2004 06:32 PM
Craig,
I am expecting 240-250HP. I've got quite a bit of dyno time budgeted for tuning the EFI. so I'll publish the numbers.
Thanks for the positive feedback...
daniel
Leland Pate 02-20-2004 08:50 PM
Eye candy, Eye candy...
Please, daddy... upload more pictures of that badboy! Those pistons look "pissed" just sitting there.
Man. That's cool.
danielt 02-22-2004 09:16 PM
New updates:
The intake has arrived. Now waiting misc. parts from PP and Injection electronics. Electronics should arrive tomorrow!!!
Doug Zielke 02-22-2004 09:32 PM
Dan,
Very interested in the SDS EFI system. Please continue the updates.
danielt 02-23-2004 10:58 AM
Okay, I found inexpensive Fuel injectors, disadvantage is they only come in sets of 8. Ford Motorsports carries Bosch FI in their catalog. Example prices for a set of 8:
19lb $209.95
24lb $229.95
30lb $239.95
38lb $399
42lb $379.95
50lb $499.95
I picked my 30lb up at Dallas Mustang.
Wayne,
This may be a less expensive way to provide Bosch injectors for the masses if you are interested in carrying them.
Daniel
danielt 02-23-2004 08:06 PM
It has arrived!!!
The SDS arrived today!!!
https://home.comcast.net/~tisserand/SDS_Install.htm
Added pictures of the Fuel injectors and the entire kit layed out.
danielt 03-14-2004 07:15 PM
New pics loaded
Just made a quick update to the pics on the web. Not much detail added to the EFI install, just pics. Will try and work in the details this week. Good news, got the EFI CPU to power up and read the installed sensors. So far, so good!!!!
Engine pics:
SDS Install update:
http://home.comcast.net/~tisserand/SDS_Install.htm
danielt 04-05-2004 07:11 PM
It lives!!!! Got through the cam break in and the first oil change. I'll try and post new pics soon. Did the first run with the SSI only, no muffler. Boy is it loud!!!! Hope to complete with a few missing parts from Pelican this week. I fried the ignition switch during all of the testing. It won't power off now, even with the key completely out. Also having trouble getting signal from the Head temp sensor. Haven't found a good place to mount and am getting poor contact, I assume.
Tim Walsh 04-05-2004 07:24 PM
VERY COOL! What kind of HP are you looking at with the EFI and 964 cams I should be there very soon.. as of tonight my motor is now complete*
*minus exhaust and fuel injection
danielt 04-06-2004 04:38 PM
Tim,
I'm guessing about 230-240HP. I will post dyno numbers in a couple of weeks once the breakin is complete. SDS highly recommends using a dyno for doing the tuning, though they have a street drive process as well.
Daniel
danielt 04-06-2004 04:39 PM
Tim,
Which EFI kit are you looking at? What are you using for a manifold?
danielt 04-17-2004 07:57 PM
Here are the latest updates:
Engine rebuild:
SDS EFI Install documentation:
Tim,
The EFI kit is from SDS. You can find them at www.sdsefi.com I used a stock manifold from a 1988 Carrera.
Thanks,
Daniel
